48Views7Replies
need info regarding replacement items in circuit.....
Hi guysI am trying to build a three stage fm transmitter and for the life of me I cannot find a 5-20p trimmer cap anywhere as well as the copper tinned coils...what can I replace the trim cap with.....a cap with a different value? and what can I replace the copper tinned coils with....normal 18 gauge wire coil?..any help will be welcomed
4 years ago
I would use a plex fine screw to lower or raise a Cu/Beryllium spring plate against a PCB Cu trace. But i don't know the ranges of the round rotating parallel Al plates...
4 years ago
Show a circuit and that would be helpful to decide what the components are doing.
i guess the trimmer cap is tuning so if you use a different value you will effect the tuning range unless you compensate by changing the coil
4 years ago
iceeng
Laymens terms please .....would you not use a trimcap?
Answer 4 years ago
Sure, but you said that you wanted to replace one.
Click the pic to see the whole image..
4 years ago
https://www.instructables.com/id/air-variable-capac...
another option, make one. Although I would try what you can get as I said the tolerance on vairable caps is huge.
4 years ago
here is the circuit and yes the trimmer cap is for tuning
4 years ago
https://www.amazon.co.uk/Capacitor-Trimmer-4-5-20p...
amazon have the trimmer cap, slightly less but the tolerance on these is huge so it should be OK. The tinned wire can be plain copper.
