98Views3Replies
Author Options:
need replacement for Koolatron heat exchanger Answered
My refrigerator died. the heat exchanger won't test. It's 3.75 x 4 inches without the radiator fins. 40 watts DC. Apparently Koolatron doesn't carry them, planned obsolescence is unethical (unless you're a shareholder). Where do replacements come from?
steveastrouk
Best Answer 5 years ago
So this is Peltier fridge ? Look on Ebay for a Peltier cell that's the same size as the one you have. You're going to have to carefully disassemble the existing unit
Jakey2steveastrouk
Answer 4 years ago
same problem with the ones on ebay and Amazon, they work for a few days and then conk out. I used thermo-paste too. too bad, the original worked fine for a year.
steveastroukJakey2
Answer 4 years ago
Could just be your mounting technique - I have stuff more than 10 years old, with the same cells.
Make the heatsinks perfectly flat by lapping them on wet and dry paper on a sheet of glass.
Apply almost transparent amounts of thermo paste
Jakey2steveastrouk
Answer 4 years ago
Thanks! I'll try that. The ones that came out, including the original, had a layer of thick white stuff like chalk where the paste should be.
steveastroukJakey2
Answer 4 years ago
It should never, ever be a thick layer. Take the wet and dry down to at least 600 grit, preferably 1000.
And a year has passed. Isn't it time you marked this as a best answer ?
Jakey2steveastrouk
Answer 4 years ago
Ok I did. I haven't tried it though, need to dig it out first.
