201Views5Replies
need some advice on how to keep my daughter and i's head from cracking!!!air dry clay?
we bought a styrofoam head from sallys beauty supply,airdry clay from micheals,and i put 1 coat over it next day it cracked off! i went thicker...still cracking...what do i do? its due in 3 days!
11 years ago
I can't personally tell you any particular information, but I can tell you from my second-hand experience (my sister was a potter) that all clay has a fair percentage of shrinkage when dried, and more so when fired. The amount depends on the type of clay, but it ranges anywhere from 2-12% from what I've seen. Types of clay that have the least shrinkage usually have smaller particles (like porcelain) and are extremely difficult to work with; crafting clay like you get from most hobby stores is similar to earthenware, which draws up 10% or more on average.
Without knowing specifically what you're trying to accomplish, the only thing I can tell you is you will have an impossible time making clay masks in this fashion. As others have suggested, you will have far better success with papier-mache or plaster casting.
11 years ago
Agreed with all the others, make it thinner:
If you can dry it in a humid environment, so that it drys as slowly as possible. Put it in a box with wet paper towels wadded in the corner.
11 years ago
Go THINNER, not thicker. Its cracking because the outer skin is drying before the interior. Thinner is better.
What's the aim ? Maybe this isn't the best way of doing what you want, in the time you have ?
Personally, I'd try papier-mache - using tissue paper as the paper and slightly diluted woodglue as the glue. Again, thick sections are bad - they won't crack, but they won't dry either....
Steve
Answer 11 years ago
I agree. Too thick. Either go thinner and layer or slow the drying so it dries equally. Also, this type of clay shrinks quite a bit while drying so you may not be able to get a totally crack free piece. You may have to fill in the cracks when it dries.
11 years ago
2 possibilities:
- the coat is too thick and/ or
- the coat dried too quickly
i suggest you peal it off the head by hand and.use sandpaper (grit size P200 or more) or a diluent, if necessary..
you should spray/ paint it in long and equal layers otherwise it will crack again.
If you'r in a hurry, you should peal or sandpaper only edges of cracks and reaplly the coat (on cracks only).
Take your time..
