5609Views9Replies
Author Options:
need to cut a hole in an altoids tin? Answered
right so im trying to make a speaker system for my bicycle and i have some smaller speakrs that i want to use an altoids tin as the box to mount on handle bars, but  i dont know what tool to use to cut the holes the speakers im guessing are about 1.5 inches in diameter.    or smaller.  anyone got any suggestions?
diyoutdoorsman
diyoutdoorsman
Best Answer 9 years ago
If you need to drill a 1-1/2" hole you can either use a hole saw or a step drill bit. Either of which should be available at most DIY centers or hardware stores.
artworker
artworker
9 years ago
Place it flat touching a wooden surface. Use nail and hammer to punch small holes making a circular array of holes. Mark the holes you require beforehand.
lynx66
lynx66
Answer 9 years ago
i agree this is the easiest way. unless you already have a dremel, which would be my first choice.
acidbass
acidbass
9 years ago
drill (as steve suggested) , dremel, i do not suggest so but exacto knives cut through aluminum also, metal files. i personally use a simple and cheap dremel if you do not have one it is a good investment but a drill could work also you just need to know what you are doing
steveastrouk
steveastrouk
9 years ago
Make a speaker grill effect by drilling with a fine drill through a piece of "perf board", which you can get from a Radio shack - mark a nice pattern on the perf board and use the 0.1" perfect spacing as the guides.
AndyGadget
AndyGadget
Answer 9 years ago
+1 to that.
I've been using the perf board method since Steve introduced me to it some time ago.  Works a treat.  I use double-sided sticky tape to hold the board down.
Not applicable in your case but if you're drilling plastic, make sure your drill bit is sharp and use a slow speed to avoid melting the plastic.
steveastrouk
steveastrouk
Answer 9 years ago
He, that was close to my first ever post on answers !
AndyGadget
AndyGadget
Answer 9 years ago
THAT's the one, all that time ago.
(No sign of the Instructable yet, Steve #;¬)
<---- That's one I did yesterday.
steveastrouk
steveastrouk
Answer 9 years ago
Yes, I was rue-ing that as I wrote the reply to the O/P......
