84Views14Replies
Author Options:
nothing happened!? Answered
nothing happened when I pushed the button
bekathwia
2 years ago
Did you successfully upload the code to your board? Can you post a picture of your circuit? Perhaps a wire is in the wrong spot.
Mike_Manbekathwia
Answer 2 years ago
It seems there is NO code going into my board. But here-
Mike_ManMike_Man
Answer 2 years ago
The only thing my board is doing is blinking... it can't get "Blink" out of it's mind... What do I do?
Mike_ManMike_Man
Answer 2 years ago
I can't even code it because of this.
bekathwiaMike_Man
Answer 2 years ago
Have you gone through the setup and first lesson and successfully programmed your board before? Do you have the correct port selected in your Tools menu? What does the software say when you try to program your board?
Mike_Manbekathwia
Answer 2 years ago
Well, I did the first and second lesson successfully, but after I put in the "blink" code in couldn't put on more lights AND have them all light up one after another... and then I couldn't code. I don't know why, but it says, "No plugin connection. Upload is disabled until you reconnect."
bekathwiaMike_Man
Best Answer 2 years ago
Revisit the Intro lesson to learn about selecting the right options in your software for programming your board: https://www.instructables.com/lesson/Tools-and-Mat...
It doesn't sound like you've successfully uploaded any new code to your board yet, so be sure to get that working before moving on to the more advanced lessons.
And make sure to plug your board in. If your USB port doesn't seem to be working, try another one or try restarting your computer.
Mike_Manbekathwia
Answer 2 years ago
I referred back to the 1st lesson but I couldn't find the button "port"
bekathwiaMike_Man
Answer 2 years ago
It's under the Tools menu. Here's the lesson (it's actually lesson 2): https://www.instructables.com/lesson/Tools-and-Mat... (the port is explained towards the bottom): "Then we need to select the communication port connected to the Arduino board. Select Tools -> Port, then whichever port name is labeled "(Arduino/Genuino Uno)." If none of your ports are labeled, try unplugging your board, checking the Ports menu, then replugging your board and checking the Ports menu again. Whichever port name disappears then reappears is likely to be your Arduino board. On Windows your port will likely be called "COM3" (or higher numbers) and on OS X it's likely to be something like "/dev/cu.usbmodem1461.""
