Connect the longer end of the LED to the +ve terminal of the battery and the shorter pin to the -ve terminal via a resistor if you are using a 9V battery a 1K resistor is fine.
Ohm's Law -> R = V/I. Input the voltage of you DC power source, divide by .02 A (20mA), that will tell you the resistor size you need in Ohms. Then wire everything in series end to end).
Best Answer 9 years ago
9 years ago
9 years ago
Force a current of about 20mA through it.
9 years ago
Add electricity - Don't forget a resistor - the shorter leg is the negative side. Look at the related column on the right >>>>>>>>>>
