78Views9Replies
Author Options:
os has trouble booting? Answered
hello, my os sometimes has trouble booting, it mostly occurs before starting work in the morning. any advice?
mpilchfamily
mpilchfamily
Best Answer 6 years ago
Need more info here.
What kind of trouble?
What OS?
knutknackebröd
knutknackebröd
Answer 6 years ago
I think its human brain, not sure what version. cant check now because its still early.
mpilchfamily
mpilchfamily
Answer 6 years ago
Guess you got a defective model. May want to see about returning it. ;)
knutknackebröd
knutknackebröd
Answer 6 years ago
That just gave me a really distubing mental image....thanks alot.......
mpilchfamily
mpilchfamily
Answer 6 years ago
Oh now your having display issues?
knutknackebröd
knutknackebröd
6 years ago
Vyger
Vyger
Answer 6 years ago
Ahhh, I see now. Well in this case then what you should do is simply quit working. Then not getting started before work will no longer be a problem. Change the things that you can change and don't waste time trying to change the things you can't. If you don't work in the morning anymore then getting things started for work in the morning will no longer be an issue.
Vyger
Vyger
6 years ago
Log off and log back on. This is not restart, its log off as user.
I have had/seen problems with some programs not starting correctly because the OS is not completely running when the programs are started. If you log off and then back on it runs the startup routine on an OS that is already fully working so things start correctly. A lot of times this problem is made worse by having a lot of start up programs and also some slow AV programs try to do boot up scanning. So once everything in the OS is running all this stuff starts the way its supposed to.
knutknackebröd
knutknackebröd
Answer 6 years ago
haha sorry to lead you on:P great answer though
