77Views12Replies
photo on metal by laser macine
I have laser machine of evlaser, Italy working with windows 98 and evedit software how i can make the photo on any metal like steel, brass.
I think this machine before year 2000.
The software of this machine is support only BMP and PLT files.
Please help me .
4 years ago
I make the picture on Brass and steel metal but when , look from front it can see if flip can't see. what is the reason.and how can solve it.the parameter used is Speed:250, Power:45, Density:7 it is coming 50 % Ok but not clear as I mentioned.
waiting for reply
thanks
4 years ago
You should be able to raster scan a bitmap.
Often called etching.
I don't know your machine so I don't know if it supports this option.
Answer 4 years ago
Thanks a lot for giving me reply.can you give me knowledge about raster scan.
and i make some picture using bitmap but it is not coming clear it is coming like dots.what is ideal parameter for 130 watt, Windows 98 operating system, laser machine for making picture on any metal specially brass and steel.
waiting for your reply
thanks again
Answer 4 years ago
Convert to smaller dots/higher resolution BMP
Answer 4 years ago
Please help me .
4 years ago
I am starting to get 8bit engraving working on my laser cutter but for metal you are definately lost if you don't have 100W (or more) power or a laser dedicated to work with metals.
Ruby lasers are great here on a hobby level.
Some medical lasers also use YAG systems, they can work on metals too depending on their wavelength.
With the limits of your controller you might need external programs to prepare a rastered bitmat of the image for the engraving.
Answer 4 years ago
Please help me .
Answer 4 years ago
Repeating the same does not help at all.
We can't help while you only run in circles ;)
Answer 4 years ago
+1.
4 years ago
You won't be able to directly etch on metal, unless its a metal cutting class laser. You CAN get a special spray that allows you to put enamel on the metal.
Answer 4 years ago
Thanks a lot for giving me answer i have 130 ND-YAG laser machine with 230 Vac,50 Hz still i am not be able to make picture on any metal.
please give me reply soon
thanks
Answer 4 years ago
You 130W ND-Yag?
With 130W you should not have any problems marking metal.
How are you driving the laser?
Is the focus set correctly?
Is the flsh tube or the LED's still ok? they don't last long in a ND yag system...
