94Views6Replies
Author Options:
please help me Answered
How to increase my range in my RC car
Tags:rc
Josehf Murchison
Josehf Murchison
Best Answer 6 years ago
Boost the power of the transmitter by adding an amplifier to the transmitter output.
Hudson samuel
Hudson samuel
Answer 6 years ago
uncle pls give me a circuit pls pls pls
Josehf Murchison
Josehf Murchison
Answer 6 years ago
Any Amp will do but try this one watt transmitter booster.
rickharris
rickharris
6 years ago
Now this is a good example of an ambiguous question.
Do you mean make it go further?
Do you mean make it run longer?
Do you mean make it possible to control further away - if so how far?
Most radio systems will allow control about as far as you can see on the ground you should get 200 yards easily
In the air you might get 1000 yards.
What type of car/battery/fuel/radio system do you have.
mpilchfamily
mpilchfamily
6 years ago
Some times a simple thing like giving the car a longer antenna will help. If the car has the antenna wrapped around itself rather than sticking up in the air, you can make it stand up and get more range.
petercd
petercd
6 years ago
You dont say whether its FM, 2.4Ghz or Infra-red, if its IR you can change the IR leds for higher power ones.
