371Views2Replies
Author Options:
please how can i make simple ir alarm that dial from mobile ? Answered
hi
please i need to make a simple circuit  that contains ir on/off switch , that will dial pre saved nimber on the mobile , for ex. , i can connect the botton (1) of the key pad in the mobile on some relay , win the alarm on it will dial the saved number
simplly , the IR will be sender and recevier , when some one or something cross the red line " the IR reays " , the circuit will be just a ON /OFF switch to run a relay
the relay will connect the dial up on the mobile device key bad
can any one help me with that ?
 Thank you all !
Grathio
Grathio
11 years ago
Unfortunately what you're asking for isn't possible with a simple circuit.
However there may be a simpler way to get the same result.  Explain the problem and maybe some of the smart folks around here can come up with a solution.
What exactly are you trying to do?  Do you want to be notified wherever you are when someone (or something) passes a motion detector?  Do you want a record of when someone used an IR remote control?  Do you want to trigger a door lock, jack up someone's phone bill, or something completely different?
wa7aa
wa7aa
Answer 11 years ago
hi , thank you for your replay :)
i did some changes in my comment , please read it again , all i need is on/off IR switch :)
thank you !
