141Views4Replies
problem with Arduino ): i don't want to use it ???
hi all
i want anyone help me in my project
first i want explain the idea of my project :-)
this project
will show you how to build a quite fancy 8 by 10 L.E.D matrix(with scrolling text and animations)
using the Arduino and 4017 decade counter. T
you can see the details of project from :
http://sohilp.blogspot.com/2011/10/tutorial-10x8-led-matrix-arduino.html
my problem::-(
i don't want to use Arduino
Can I use parallel port Instead
ArduinoØï¿½Øï¿½Øï¿½
if you tell yes how i:|?
and how to make the new circle
plz help me or give me any like about this
thank you
:oops: i am waiting for all
[/LEFT]
8 years ago
and then
Which is it?
Answer 8 years ago
i means can i use parallel port Instead Arduino
Answer 8 years ago
Probably yes. You'll need to know how much current/voltage parallel can source or sink. I'm sure it is in the range of arduino, but may be +-12V. Check!
Serial is another option. Again, it'll probably be RS232 at +-12V. You can get RS232 to TTL converters though, and a serial to parallel chip. That'll let you control your LEDs via a serial port.
Your formatting is all messed up on this question. I can't read half of it, so I hope I have guessed right.
Answer 8 years ago
i liked it but the problem is my teacher doesn't want me to work with Arduino . she said try to find like this project " Matrix LED" but by using
parallel port + db25 + microprocessor
