1334Views17Replies
Author Options:
programming a stealth USB caps locker problems? Answered
i have a problem programming my stealth USB caps locker (link
the PCB is ready, the components soldered on, and ive made connections to my ghetto programmer.
now, i opened programmers notepad and wanted to program it, but now it just gives a whole load of errors:
> "make.exe" program
set -e; avr-gcc -MM -mmcu=attiny45 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=main.lst  -std=gnu99 main.c \
    | sed 's,\(.*\)\.o[ :]*,\1.o \1.d : ,g' > main.d; \
    [ -s main.d ] || rm -f main.d
main.c:19:20: error: usbdrv.h: No such file or directory
main.c:20:21: error: oddebug.h: No such file or directory
Compiling: main.c
avr-gcc -c -mmcu=attiny45 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=main.lst  -std=gnu99 main.c -o main.o
In file included from main.c:16:
c:/winavr-20090313/lib/gcc/../../avr/include/util/delay.h:85:3: warning: #warning "F_CPU not defined for <util/delay.h>"
main.c:25: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'reportBuffer'
main.c:26: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'idleRate'
main.c:27: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'reportCount'
main.c:33: error: 'USB_CFG_HID_REPORT_DESCRIPTOR_LENGTH' undeclared here (not in a function)
main.c: In function 'buildReport':
main.c:65: error: 'uchar' undeclared (first use in this function)
main.c:65: error: (Each undeclared identifier is reported only once
main.c:65: error: for each function it appears in.)
main.c:65: error: expected ';' before 'key'
main.c:68: error: 'reportCount' undeclared (first use in this function)
main.c:69: error: 'key' undeclared (first use in this function)
main.c:73: error: 'reportBuffer' undeclared (first use in this function)
main.c: In function 'timerPoll':
main.c:87: error: 'reportCount' undeclared (first use in this function)
main.c: At top level:
main.c:104: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'usbFunctionSetup'
main.c: In function 'calibrateOscillator':
main.c:143: error: 'uchar' undeclared (first use in this function)
main.c:143: error: expected ';' before 'step'
main.c:144: error: expected ';' before 'trialValue'
main.c:149: error: 'trialValue' undeclared (first use in this function)
main.c:149: error: 'step' undeclared (first use in this function)
main.c:150: warning: implicit declaration of function 'usbMeasureFrameLength'
main.c:157: error: 'optimumValue' undeclared (first use in this function)
main.c: In function 'main':
main.c:193: error: 'uchar' undeclared (first use in this function)
main.c:193: error: expected ';' before 'i'
main.c:194: error: expected ';' before 'calibrationValue'
main.c:196: error: 'calibrationValue' undeclared (first use in this function)
main.c:200: warning: implicit declaration of function 'odDebugInit'
main.c:201: warning: implicit declaration of function 'usbDeviceDisconnect'
main.c:202: error: 'i' undeclared (first use in this function)
main.c:205: warning: implicit declaration of function 'usbDeviceConnect'
main.c:211: warning: implicit declaration of function 'usbInit'
main.c:215: warning: implicit declaration of function 'usbPoll'
main.c:222: warning: implicit declaration of function 'usbInterruptIsReady'
main.c:222: error: 'reportCount' undeclared (first use in this function)
main.c:224: warning: implicit declaration of function 'usbSetInterrupt'
main.c:224: error: 'reportBuffer' undeclared (first use in this function)
make.exe: *** [main.o] Error 1
> Process Exit Code: 2
> Time Taken: 00:03
maybe its this:
""Download capslocker.hex and use AVR Studio or a standalone programming tool to write into the ATTiny45 Flash. Oh, you'll also need to select the fuse for PLL/1k clock source."
thats what the maker of this thingie said, but what is the fuse for PLL/1k clock source? could it be that?
when i use the .hex file, i get about the same.
whats the problem? i didnt change anything.
lemonie
lemonie
Best Answer 10 years ago
The complier is telling you something here: h: No such file or directory
Is the h:\ drive there and functional when you do this?
The rest looks like rotten-source to me?
L
godofal
godofal
Answer 10 years ago
its in the same folder, so i guess its  there...
anyway, what could be rotten? i havent altered anything, and it should run ok, its a clean download...
godofal
godofal
Answer 10 years ago
ive made some screenshots:
godofal
godofal
Answer 10 years ago
ah, i found out that those 2 missing .h items where in that usbdrv folder, ive copied everything in the main folder, and i get alot less errors now.
this is what i have left:
> "make.exe" program
set -e; avr-gcc -MM -mmcu=attiny2313 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=main.lst  -std=gnu99 main.c \
Compiling: main.c
avr-gcc -c -mmcu=attiny2313 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=main.lst  -std=gnu99 main.c -o main.o
main.c: In function 'timerInit':
main.c:96: error: 'TCCR1' undeclared (first use in this function)
main.c:96: error: (Each undeclared identifier is reported only once
main.c:96: error: for each function it appears in.)
> Time Taken: 00:02
lemonie
lemonie
Answer 10 years ago
You seem to be doing a good job of fixing this - you should be able to read the remaining error messages and fix them too?
L
godofal
godofal
Answer 10 years ago
i think its a problem  with the makefile, the makefile that was in the download doesnt work at all, and with my own makefile i alot of errors...
godofal
godofal
Answer 10 years ago
okay, i dont think i can get further on my own...
these are the last errors, theyr mostly about some undefined stuff, but i just cant find what they should define in the code...
> "make.exe" program
Linking: main.elf
avr-gcc -mmcu=attiny45 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=main.o  -std=gnu99 main.o   --output main.elf -Wl,-Map=main.map,--cref -lm
main.o: In function `usbFunctionSetup':
I:\portableapps\programmers notepad\programma's\CapsLocker/main.c:108: undefined reference to `usbMsgPtr'
I:\portableapps\programmers notepad\programma's\CapsLocker/main.c:115: undefined reference to `usbMsgPtr'
main.o: In function `main':
I:\portableapps\programmers notepad\programma's\CapsLocker/main.c:211: undefined reference to `usbInit'
I:\portableapps\programmers notepad\programma's\CapsLocker/main.c:215: undefined reference to `usbPoll'
I:\portableapps\programmers notepad\programma's\CapsLocker/main.c:222: undefined reference to `usbTxLen1'
I:\portableapps\programmers notepad\programma's\CapsLocker/main.c:224: undefined reference to `usbSetInterrupt'
main.o: In function `calibrateOscillator':
I:\portableapps\programmers notepad\programma's\CapsLocker/main.c:150: undefined reference to `usbMeasureFrameLength'
I:\portableapps\programmers notepad\programma's\CapsLocker/main.c:160: undefined reference to `usbMeasureFrameLength'
make.exe: *** [main.elf] Error 1
> Time Taken: 00:01
how can i find out how i have to define this? or  can anyone else figure it out?
lemonie
lemonie
Answer 10 years ago
I'm not that familiar with this stuff. You might ask another question, very specifically towards "compile error help". This question has dropped out of recent, and as we're the only two discussing it, having a fresh go might catch someone who knows the stuff better.
L
godofal
godofal
Answer 10 years ago
k, ty for ur help.
lemonie
lemonie
Answer 10 years ago
You got two other people on that other question - stick with 'em as I think they'll be more help than me.
L
godofal
godofal
Answer 10 years ago
they were :D
ive programmed it now.
the main problem was that it was made in AVRstudio, and i couldnt use that becouse it wouldnt open the project (it would crash) and it didnt support my ghetto programmer...
but ive used a CMD line with avrdude to load the .hex file directly into the chip
it should work now, im testing it but nothing so far...
maybe thats the fuse settings so il try to change those soon
anyway, thnx for all the time and efforts
lemonie
lemonie
Answer 10 years ago
Oh good, glad about that, but still not working is a bit odd. Does the PC pick the device up - I'm guessing that it should in some way?
L
godofal
godofal
Answer 10 years ago
yeah, it says USB device not recognised, sometimes nothing at all (but that can be bad connection)
lemonie
lemonie
Answer 10 years ago
If the PC doesn't have a functional "connection" in place, it ain't going to work. Should it use generic drivers or do you need to install some?
L
hsandford
hsandford
Answer 10 years ago
Check that you've got the usbdrvasm.s file in the right directory, try putting it in the same directory as the .h files you had problems with previously.  Or if you already have it there, then make sure it's in the ./usbdrv/ directory instead.
1051100720
1051100720
10 years ago
Hi!!
How did u get rid of the "c:/winavr-20090313/lib/gcc/../../avr/include/util/delay.h:85:3: warning: #warning "F_CPU not defined for <util/delay.h>"" warning??
I've been trying and trying but it stays!
godofal
godofal
Answer 10 years ago
it was something in the makefile...
not sure what it was specifically though.
send me a message with more info, and il try 2 help u out as far as possible ;)
