66Views3Replies
Author Options:
push button contacts fail Answered
hi,
i disassembled my full-automated coffeemachine as the push buttons for programs failed. The buttons are a line of rubber and the contacts on the platine are toothed while each rubber contact got tiny plates that bridge the contacts on the platine. I guess that the contact plates lack of conductivity - any suggestions what i can do to improve the conductivity? I thought bout buying contact foil and glue it over the rubber contacts, but i don't know, if this is the best solution.
caitlinsdad
caitlinsdad
5 years ago
Use a pencil eraser to clean the contact surfaces. There may be a light film of oxidation or grime from the rubber buttons. You can use a voltmeter to conduct the basic conductivity tests while the machine is unplugged from the mains. Good luck.
Kiteman
Kiteman
5 years ago
Test that the plates are the problem first.
If possible, and being very careful, power-up your machine with the platine (circuit board?) exposed, and use a screwdriver with a rubber handle to touch across the contacts. Does it start working? Then you are right. Doe it not? then the problem is something else.
Luziviech
Luziviech
Reply 5 years ago
ok, will try that out first.
