82Views7Replies
Author Options:
quickest glue? Answered
quick glue led wires into under cabinet corners   what to use
designmore2
designmore2
5 years ago
Hi: Thank You: I used a combination approach of hot glue and super glue, depending on where the adhesive was needed. I also want to try the loca glue... it sounds like it would be a great resource. Also, I used pieces of two sided adhesive clear 3m tape, to hold wires temporarily while gluing.
Yonatan24
Yonatan24
5 years ago
I recommend using Hot Glue, I've used it before for LED Strips and it works really well
Don't worry, It won't melt from the heat of the LED's
Downunder35m
Downunder35m
5 years ago
Loca glue - cures with UV light in an instant.
superglue fails on most modern plastics.
CabbitCastle
CabbitCastle
5 years ago
I'd recommend hot glue.
Unlike super glue (cyanoacrylate, can be set instantly with something like Zip Kicker or baking soda) it is easily removeable if you decide to remodel one day.
Rmoval can be made easier by using a cryo spray on the hot glue first.
If it's meant to be permanent, go for super glue like Kiteman mentioned.
Kiteman
Kiteman
5 years ago
Super glue takes seconds.
rickharris
rickharris
Answer 5 years ago
With a kicker more or less instnt.
