45Views14Replies
Author Options:
resistors Answered
how many ohm resistor would i need to resist 7 volts to 3.5 volts and 12 volts to 3.5 volts also....
Yerboogieman
Yerboogieman
13 years ago
but for this project i will need a zener diode because im only using one fan and 2 switches, that reminds me, how would i use one switch to switch between 7 and 12 volts?
Goodhart
Goodhart
Reply 13 years ago
If I understand you correctly here, a SPDT or DPDT switch should serve your purpose (Single pole, double throw; Double pole Double throw)
chooseausername
chooseausername
Reply 13 years ago
If i try to translate your description : - you would like to be able to change the speed of a 12V fan using a switch Is this correct ? Though, i don't know what you want to do with the LED ... Questions : 1) Why 7V and not 6V or 4.5V or anyother value ? 2) What do you want to use the LED for ?
Yerboogieman
Yerboogieman
Reply 13 years ago
because in a computer they have 4 wires, 12v, 2 ground wires, and 7 volts, the LED to show what voltage is going through it, and i would like to change the speed of a 12v fan.
Yerboogieman
Yerboogieman
Reply 13 years ago
for example, a green LED to show 7v and yellow to show 12v
NachoMahma
NachoMahma
Reply 13 years ago
. Actually, it 12V and 5V (plus grounds). . Most computer fans can be controlled with a potentiometer or PWM module. Or, using the 12/5/G connector, you can wire a switch to send 0-5-7-12V to the fan. . From what I've read (but no experience), most 12V fans don't work well below 6-7V or so.
Danny
Danny
Reply 13 years ago
aww for a second i thought that was a "knight rider" cuircuit
Danny
Danny
Reply 13 years ago
opps circuit
lemonie
lemonie
13 years ago
If you're thinking of resistors think in terms of current.
If your total is e.g. 100mA, the 3.5V component will have a resistance (or equivalent) of 3.5/0.1 = 35 Ohm.
The rest of your system will have (12-3.5)/0.1 = 85 Ohm. (Totals 120 ohm, 100 mA @ 12 V)
And the power consumption of the 85 Ohm resistor would be (12-3.5)*0.1 = 850mW
L
(or did I get that wrong?)
Yerboogieman
Yerboogieman
13 years ago
well just for an LED and then im hooking computer fans to them
chooseausername
chooseausername
13 years ago
Yes, a voltage regulator would be more appropriate if you want to use it as a source of current. On the other hand, if you just need a voltage reference (without the need of a current) you could make a voltage divider with two resistors (see wikipedia) or use a zener diode ... And of course, if you want a correct and appropriate answer to your specific problem, i think you should give us some more informations about your montage.
