97Views7Replies
Author Options:
robot help Answered
hello guys i was trying to make a beetle bot following the instructions from this site everything went fine but i had 2 broblems that arent totaly solved yet... the wheels to the motor i have no idea how to make em if i buy em they come all different size and the tip of the motor that spins is like verry little grip i hope u understand... and other thing is everything was fine but at the end when my bot suppose to run it didnt it was getting on and off every now and then when i put em on the floor it wont go i was thinking it was heavy but even if it was heavy i am wondering y it was getting on and off every now and then.... can you plz answer both i need to make it its cool
duseksp
duseksp
11 years ago
has anyone made a robot from a Jazzy power wheel chair?
Kiteman
Kiteman
Reply 12 years ago
Ok... The stopping thing, that's lack of power - batteries flat, weak motors, heavy robot. Maybe wheels too large. The switch error - that's wiring. I can't see what you've connected where, but I am strongly tempted to tell you to desolder everything and start again, going slowly.
sydazak
sydazak
Reply 12 years ago
i havent solder anything i just twisted ... back to the wheels smaller meANS I need to find some house hold items i cant.... i was figuring out the lack of power thing the batterys are fuly charged and how do i reduce the weight , thats why i tried doing full power the battery case is 4 batterys to bump the power still i had same problem its getting on and of do u thin its cause is because i didnt soldier it ?.... sorry for bothering u bro but i am tempted to make it..:)
Kiteman
Kiteman
12 years ago
Wheels
Pinch them off a toy car, or make them from a pair of identical bottle-lids filled with epoxy. Use rubber-bands as tyres for grip.
If the shaft of the motor is very smooth, scratch it with a file or roughen it with sandpaper to make glue stick.
getting on and off
If it is switching on and off as you handle it, then something is loose - either a joint is not very solid, breaking the circuit occasionally, or there is a short - a bit of wire or metal connecting bits that shouldn't be connected.
Do your batteries get warm even if the bot isn't running? Then it's a short, quick, take out the battery before it melts the holder (I've seen that happen) and check your wiring.
(If that doesn't help, maybe post a photo of the wiring?)
sydazak
sydazak
Reply 12 years ago
The only thing not stated is that i dont have the third connector from the battery.
Video
invalid movie: http://www.zippyvideos.com/8113817887730076/zak_bot/
