150Views11Replies
Author Options:
servo programming on arduino? Answered
hi,
i need a help on my arduino project.
i need to make daily program my servo motor on arduino. for example;
23:00 at night ,it should turn right 90';
8:00 at morning, it should turn left(back) 90'
also;
when i need; i should turn this servo, left-right manually via internet.
how can i make this, which component i should use, which commands i should use?
any tutorial, or samples like this?
i found some examples on instructables like using servo via internet, Control a Servo over the Internet etc. but i dont know how make this two option together.
ps my arduino level: intermediate
tI appreciate any help that you can provide :)
herneise
herneise
4 years ago
// this is the first part that i am working on, the programming part.
//after that i am planning to start on internet part
//i use as a base tutarial : https://www.instructables.com/id/Arduino-Timer-With...
//waiting for your comments
//thanks
#include <LiquidCrystal.h> //Libraries
#include <RTClib.h>
#include <Wire.h>
// servo things:
#include <Servo.h>
Servo s1; //servo 1
#define SERV1 13 //servo 1 on digital port 13
int pos1 = 170; //servo 1 current position
int vel = 10; //servos' speed (100 -> 90º in 1 s)(1 -> 90º in 9 s)
int pos1min = 10; //servo 1 minimum position
int pos1max = 170; //servo 1 maximum position
LiquidCrystal lcd(2, 3, 4, 5, 6, 7); //Arduino pins to lcd
//LCD 1602
//RS to 2pin, EN to 3pin, D4 to 4pin, D5 to 5pin, D6 to 6pin, D7 to 7pin
//Contrast= 10K potentiometer: 1 to Vcc, 2(center)to VO, 3 to GND
//Backlight= K to GND(with 1K resistor), A to Vcc
//Vss to GND , Vdd to +5v
RTC_DS1307 RTC; // define the Real Time Clock object
//RTC 1307
//SDA to analog 4, SCL to analog 5
//You need 4 buttons like this,to enter the set points, with 10K resistor to ground (for each one)
// To arduino pins(8, 9, 10, 11)
// switch |
// _______ | 10K
// +5V 0-----0 0----0------/\/\/\/\-------0 to GND
const int DOWN_BUTTONon =9; //Buttons Pins
const int UP_BUTTONon =8;
const int DOWN_BUTTONoff =11;
const int UP_BUTTONoff =10;
//-----Variables for debouncing------//
boolean lastDownONButton = LOW;
boolean currentDownONButton = LOW;
boolean lastUpONButton = LOW;
boolean currentUpONButton = LOW;
boolean lastDownOFFButton = LOW;
boolean currentDownOFFButton = LOW;
boolean lastUpOFFButton = LOW;
boolean currentUpOFFButton = LOW;
int set_on = 12; //The default "ON" desired time
int set_off= 12; //The default "OFF" desired time
void setup(){
//attach and set servo angles
s1.attach(SERV1);
s1.write(pos1min);
pinMode(SERV1, OUTPUT);
Wire.begin();
RTC.begin();
lcd.begin(16, 2); // Configura lcd numero columnas y filas
lcd.setCursor(0,0); //Show "TIME" on the LCD
lcd.print("TIME");
lcd.setCursor(0,1);
lcd.print("ON"); //Show "ON" on the lcd
lcd.setCursor(6,1);
lcd.print("OFF"); //Show "OFF" on the lcd
//----Debouncing function for all buttons----//
boolean debounce(boolean last, int pin)
boolean current = digitalRead(pin);
if (last != current)
delay(5);
return current;
void loop(){
//--------Show current Time On LCD--------//
DateTime now = RTC.now(); // Clock call
now = RTC.now();
lcd.setCursor(5,0);
if(now.hour() < 10)
lcd.print("0");
lcd.print(now.hour(), DEC); //Print hour
lcd.print(':');
if(now.minute() < 10)
lcd.print("0");
lcd.print(now.minute(), DEC); //Print min
lcd.print(':');
if(now.second() < 10)
lcd.print("0");
lcd.print(now.second(), DEC); //Print sec
//----Debounce buttons---//
currentDownONButton = debounce(lastDownONButton, DOWN_BUTTONon);
currentUpONButton = debounce(lastUpONButton, UP_BUTTONon);
currentDownOFFButton = debounce(lastDownOFFButton, DOWN_BUTTONoff);
currentUpOFFButton = debounce(lastUpOFFButton, UP_BUTTONoff);
//-----Turn down the set "ON"-----//
if (lastDownONButton== LOW && currentDownONButton == HIGH)
if(set_on>0){ //"ON" Set point down never lower than 0
set_on--;
else{
lcd.setCursor(3,1);
lcd.print("0");
//----Turn up the set "ON"----//
else if (lastUpONButton== LOW && currentUpONButton == HIGH)
if(set_on<23){ //"ON" Set point up never higher than 23
set_on++;
else{
lcd.setCursor(3,1);
lcd.print("23");
//---Print the set "ON"---//
lcd.setCursor(3,1);
if(set_on < 10){
lcd.print("0");
lcd.print(set_on);
lastDownONButton = currentDownONButton;
lastUpONButton = currentUpONButton;
//-----Turn down the set "OFF"-----//
if (lastDownOFFButton== LOW && currentDownOFFButton == HIGH)
if(set_off>0){ //"OFF" Set point down never lower than 0
set_off--;
else{
lcd.setCursor(10,1);
lcd.print("0");
//----Turn up the set "OFF"----//
else if (lastUpOFFButton== LOW && currentUpOFFButton == HIGH)
if(set_off<23){ //"OFF" Set point up never higher than 23
set_off++;
else{
lcd.print("23");
//---Print the set "OFF"---//
if(set_off < 10){
lcd.print("0");
lcd.print(set_off);
lastDownOFFButton = currentDownOFFButton;
lastUpOFFButton = currentUpOFFButton;
//----Servo Function----//
if(set_on == set_off){
s1.write(0);
if(set_on > set_off){
if(now.hour() >= set_on && now.hour() < set_off ){ //Start
s1.write(180);
else if(now.hour() >= set_off) {
s1.write(0);
else{
s1.write(0);
if (set_on < set_off){
if(now.hour() >= set_on && now.hour() <= 23){ //Start
s1.write(180);
else if(now.hour() < set_off){
s1.write(180);
else if(now.hour() >= set_off && now.hour() < set_on){
s1.write(0);
}// The End
steveastrouk
steveastrouk
Answer 4 years ago
Does it do what yiou want when you set it ? It looks like you need better bracketing around the if expressions.
if ( (now.hour() >= set_off) & (now.hour() < set_on) ){
steveastrouk
steveastrouk
4 years ago
Show us an example of the servo-internet code you have, and we can look at how to modify it.
herneise
herneise
Answer 4 years ago
answered above.
thanks.
steveastrouk
steveastrouk
4 years ago
Its easy. All you need to do is put timer conditions on the servo statements that the internet commands activate.
herneise
herneise
Answer 4 years ago
hi,
possible to be more detailed?
thanks
iceng
iceng
Answer 4 years ago
I cant remember do you have to maintain the timing to hold position or does power off lock the position ?
Downunder35m
Downunder35m
Answer 4 years ago
Depends on how you implement it and what library you use.
Some prefer to do a full swing and return to middle position before normal operation, others prefer to simply stay in the last position.
Had to play with this when I tried my skills on a small laser scanner...
I guess the standard is to stay where it was left.
herneise
herneise
Answer 4 years ago
as i told on the top, i need to turn the knob at 23:00 to right. wait there.(hold position) and 8:00 turn back again. and hold position there. and repeat this loop everyday + wifi control whenever i want.
herneise
herneise
Answer 4 years ago
herneise
herneise
4 years ago
to be more clear;
i need to control this knob. this is for our heating system. in russia, there are 2 shift for electrical payment cost.
from 8:00 to 23:00 it costs 0,04 usd/kw; 23:00 to 8:00 it costs 0,02 usd/kw
i can not arrange it by ordinary timer etc, because incoming power is 9kw( heating system uses 9 kw) so the simple way to control is , turn this knob.
thanks for answers. possible to be more detailed?
