205Views3Replies
Author Options:
should the brake fluid be changed with replacement of brake disk? Answered
should brake fluid be replaced after certain time
NachoMahma
NachoMahma
11 years ago
. Silicone-based brake fluid (DOT5) does not need to be changed under normal circumstances. Glycol-based brake fluid (DOT3 and DOT4) should be changed every 1-3 years (primarily because it is hygroscopic), but will last more than 5 under favorable conditions.
lemonie
lemonie
11 years ago
People do tend to recommend replacing brake fluid after a couple of years, but you should check your car's manual / handbook - it ought to tell you what is recommended by the manufacturer. L
vince 09
vince 09
11 years ago
I don't think it needs to be you might top it off make sure its full tho
