113Views1Replies
Author Options:
simple power supply Answered
I have a project that needs a 24VDC input, at only about 300 mA. I don't have any 24V power supplies, wall warts or anything else lying around, but what I do have is a 120 in, 24 out transformer, a bridge rectifier, and a large cap. Is there any reason why I shouldn't just use those? I'll put a fuse on it. I have some 317 voltage regulators but they dissipate too much to provide the full 24V. 317s are short-protected and the like, which obviously my little kludge wouldn't be, but beyond that, is it a bad idea? thanks,
Sandisk1duo
Sandisk1duo
12 years ago
that shouldn't kill you, electricity can't go thru skin unless it's over 24v you can go look at your local thrift store, they should have a bin filled with adapters and other paraphernalia. Check the working voltage for the bridge rectifier, then the voltage of the cap, the cap should be >30v. wierd things happen when i try to rectify AC the voltage somehow gets aplified, if put in 13v, get 14 out....
