2284Views18Replies
Author Options:
small and quiet air compressor for a single pipe organ pipe? Answered
I've got a 2m long pipe (that I can blow with my lungs). I want to make it into a doorbell but don't have a compressor.
I tried a car horn compressor but it is so loud that it totally drowns out the pipe!
Any other ideas?
dwyan
5 years ago
Hey I've seen this befor but how did you get ahold of the plans from the December edition of popular mechanics I've been trying to get a hold of it?
Greasetattoo
7 years ago
How about a bellows...
Here is mine..
Still have some fine tuning to do.
sd12717Greasetattoo
Answer 6 years ago
Do you have directions on how to build this?
Greasetattoosd12717
Answer 6 years ago
Yes...
Here you go.
Enjoy, and post some finished pictures.
Mine still needs tuning...
As the weather changes, so does the tuning...
http://books.google.com/books?id=-9kDAAAAMBAJ&pg=PA102&dq=calliope+mechanics&hl=en&sa=X&ei=U5eTUcaCNMTYyQHYx4GIDA&ved=0CDcQ6AEwAA#v=onepage&q=calliope%20mechanics&f=false
sd12717Greasetattoo
Answer 6 years ago
THANK YOU YOU ARE THE BEST!!!!!!! :D i just hope im as talented with mechanics to do it!!!!!!!!! IM JUST SO :D Yay! Thank you!!! If i end up doing it, i will try to post it for you!!!
matthewvenn
7 years ago
Thanks all! I used compressed air can in the end, enjoy the video!
http://www.youtube.com/watch?v=70fWGE0hydo
rickharris
7 years ago
Get a large can - Put inside the bladder from a football. Between the bladder and the can put a home made pressure switch as in diagram.
matthewvennrickharris
Answer 7 years ago
one thing I forgot to make clear was that I want to use this as a doorbell, so a relatively 'once off' thing could work. It doesn't matter if the tube can only make a sound once a minute or whatever.
rickharrismatthewvenn
Answer 7 years ago
Use an aerosol compressed air can - through a pressure reducer to lower the volume a bit. Setting it off might be a problem though.
Answer 7 years ago
This is what I've gone for, it works pretty well; the only problem is that the can will need to be replaced every now and then, and that the sound of the hiss from the can is audible.
Answer 7 years ago
had a different thought - A weighted bicycle pump where the bell push releases the weight so pumping a blast of air through the pipe (may need bellows to get volume rather than a pump ).
A motor can lift the weight to re-set the alarm.
Greasetattoo
7 years ago
About the Bellows...
Make it like this:
http://www.ebay.com/itm/Train-whistle-6-chime-sounds-like-steam-train-realistic-/120756518712?pt=LH_DefaultDomain_0&hash=item1c1da63f38
(this is not my ad, just using as a example)
steveastrouk
7 years ago
Use a storage tank, and a very small compressor. Discharge the tank through a nice fat piloted air valve.
Steve
matthewvennsteveastrouk
Answer 7 years ago
like a car tyre compressor? I'd probably need a pressure sensor then for the storage tank as well right? So I turn on the compressor when pressure is too low and then off again when it's high enough.
Matt
steveastroukmatthewvenn
Answer 7 years ago
That's the kind of thing I was thinking of. You could do your own, but you need special on/off switch - I'd contemplate buying somehting from Machine Mart or off Ebay.
Steve
