830Views2Replies
spong no. 2 coffee grinder
where can I get the replacement catcher cup?
I just got one and it needs cleaning
ok just dishwashing soap?
how long will I leave it outside to dry?
any recommendations on what to spray it with?
the paint is good, i just want a spray to prevent rust
and would like to use it for my french press coffee in am.
thank you
7 years ago
for a catcher cup, try spongenalia on ebay
7 years ago
Burf has already given you a good summary. You can also look at the top two "related" I'bles, in the lower right sidebar:
https://www.instructables.com/id/restoring-a-coffee-grinder./
https://www.instructables.com/id/Restoring-a-Coffee-Mill-Spong-No3/
7 years ago
Unless you are looking for an original I would just use a small glass or porcelain bowl for the catcher. If you're looking for an original, ebay would be a good place to start.
To clean, disassemble and all let all of the metal parts soak in boiling hot soapy water for 10-15 minutes then scrub with stiff brush. Rinse thoroughly and dry with compressed air blower. Lightly coat the gear and shaft mechanism with mineral oil (not the burr.)
To protect the painted finish, use a satin finish, clear polyurethane spray paint.
Once you have it re-assembled, grind a couple of cups of cheap coffee beans and toss them away. You should be ready for the good stuff then.
