2505Views7Replies
Author Options:
strong electromagnets that repel each other? Answered
I have two electromagnets already but they aren't strong enough to really push each other. I've read mixed things online about electromagnets that repel being very weak. I would like to build something like a shock absorber with a electromagnet at each end so when their is a load on the shock absorber the electromagnet can push back and stiffen. Any ideas on this would be awesome, i've spent a lot of hours researching online already but cant seem to find good info.
Thanks
Sounder242
Sounder242
3 years ago
Im also do a same project and i want to know information about repel distance gap between the two ekectro magnet?
Electromagnet detail
Model no is M52172
Diameter 25mm
Thickness 20mm
Holding force 11.5kg
Works with 12v/24v DC
Jan_Henrik
Jan_Henrik
6 years ago
Can you post some pictures of the Magnets and more data please, I would like to know the Voltage and current, also if you use a Ferrit core or not... :)
chrisack
chrisack
Answer 6 years ago
Two DC electromagnets, the specs are:
5.5 lbs of lifting force
12vdc, 3 watts continuous duty
Im not sure of the core?
Jan_Henrik
Jan_Henrik
Answer 6 years ago
Okay, interresting. These looke kind of strong... If they arent strong enought, the use neodym magnets, they are very strong!
tanyutsharma
tanyutsharma
6 years ago
You can attach a very strong permanent magnet at one end and make a electromagnet at the other. The power necessary for the electromagnet will be minimised by this.
chrisack
chrisack
6 years ago
Is it even possible to make two electromagnets repel each other from a 1/2 inch distance gap between the two?
Thanks
rickharris
rickharris
Answer 6 years ago
yes - in principle. see my other post - current, core and distance all effect the repultion
rickharris
rickharris
6 years ago
You will actually get a better result from neodymium permanent magnets. Much greater flux density.
To increase the efficiency of th electromagnets you need a good iron core, a healthy winding of wire, as much current flowing as the wire will stand and a minimal gap between the magnets. All these things effect the strength of the magnetic field.
