1954Views8Replies
Author Options:
system that takes BCD inputs from DIP Switches and display Decimal on 7-Segment display, without using any BCD Decoder? Answered
hi i want to make system that takes BCD inputs from DIP Switches and display Decimal on two 7-Segment display, without using any BCD Decoder.what ic should i choose??and circuit.
steveastrouk
steveastrouk
5 years ago
There are plenty of options. Your problem is that you have been told to use only an AND gate, and you need an inversion.
iceng
iceng
5 years ago
You can make a tripl-input AND gate from three dual-input NAND gates and
make a four-input NAND gate from from five dual-input NAND gates.
Make two duplicate sets for two Seven Segment Displays.
iceng
iceng
5 years ago
Use a BCD to Decimal IC gates 7445 and 50 1N5817 Diodes to decode ten to 7-Segment LED display see the circuit below.
szafar2
szafar2
Answer 5 years ago
i have to make without using bcd to decimal ic,only 74LS11 but for two 7-segment display.
iceng
iceng
Answer 5 years ago
Replace the 7445 with five dual 4input 7421 IC AND gates and
Three 7414 IC Hex Inverters
steveastrouk
steveastrouk
Answer 5 years ago
I spy with my little eye something beginning with "homew"
rickharris
rickharris
5 years ago
Why? Manufacturers make the chips because doing it otherwise takes a lot of logic.
szafar2
szafar2
Answer 5 years ago
because its semester project.
steveastrouk
steveastrouk
5 years ago
You can do it with discrete logic, and lots of it, there are plenty of on line references.
szafar2
szafar2
Answer 5 years ago
can you have any idea about which ic i use?i want to use 74LS11.
steveastrouk
steveastrouk
Answer 5 years ago
You need triple input NANDs or NORs
