88Views3Replies
Author Options:
trail counter Help Answered
Ok I need some help. I am a trail steward on a local mountain bike trail. We want to make a counter so we can find out how many folks are using the trail. I thouhgt I had a good idea, but can't seem to make it work. I have access to a bunch of garge door photo sensors(neighbors a garage door tech), and a bunch of thoes pocket pedometers(got them from a manager of a Mcdonalds when they stopped giving them out). I have figured out how to make the pocket counters work as just plain counters thanks to another instructable (remove hammer, wire across with a switch or relay...). What I have not been able to figure out is how to use the garage door sensors to make the circuit work. All I need is for the circuit to make a relay close to act as the switch for the counter. I was able to do it with an LED emmiter and detector and it's circuit, but for soome reason I guess the garage door sensors have something inside their glued box that won't let it work with the circuit. Any ideas?
LinuxH4x0r
LinuxH4x0r
12 years ago
Use the sensors to power a relay connected to a pedometer
westfw
westfw
12 years ago
Another possibility is that the Garage door circuits use an internal "solid state relay" that only works on AC, rather than a normal mechanical relay.
NachoMahma
NachoMahma
12 years ago
. The detector output may not be able to handle the current of the relay coil. . IIRC, garage door safety switches are wired so that they are open when not detecting the beam. This may be causing problems. . Aiming is critical. . If ambient light is interfering, try using a tube on the receiver.
