88Views3Replies
Author Options:
triac switchero Answered
I have a touch light switch I bought from my local lighting store the triac and heat sink stands too tall for the base of the light ,I want to desolder the original and replace it with a new one with longer leads so I can lay it down to fit inside the base. How do I know if my new triac is compatable they look like they are the same size numbers are different.
Tags:light
dannobe
dannobe
5 years ago
Hi....i always try to see if Numbers on Device(s) can be first found in
Electronic Parts Data Base Web Sites.....try these...
http://www.alldatasheet.com/
http://www.datasheetcatalog.com/
http://www.datasheetarchive.com/
http://www.datasheetpro.com/
....if not try again, but omitting prefix-alpha's......just use digits only....
.....then see if it is listed in supplier catalogs, so that replacement parts could be
obtained, later.....and any special insights can be had...
http://www.jameco.com/webapp/wcs/stores/servlet/St...
http://www.allelectronics.com/
https://www.radioshack.com/
One thing about Triacs is if Metal Tab is / is not connected to middle Pin...
It matters because your Heatsink would be electrically one side of the Power-Line , if it were !
Anyway....hope this helps.....
Cheers
dannobe @sbcglobal.net
