148Views3Replies
upgrading my PC need power advice?
hey all,
i'm going to be upgrading my PC soon and need to know if i'll need a new PSU to go with it.
CPU: AMD FX 8150
Motherboard: Asus Crosshair V Formula-Z
GPU: Sapphire ATI Radeon 7970HD
current PSU: Hytec 950w (can't get any better info than that)
Side question:
will an Asus Commando, intel q6600 & ati 5450 run on a 380w psu?
it will only be acting as a "server" of sorts no heavy lifting
Best Answer 8 years ago
Use this online calculator to estimate your PSU needs: http://extreme.outervision.com/psucalculatorlite.jsp
Answer 8 years ago
i ran my system through that and it was giving me some "interesting" results
High end Desktop
Q6600
ati 7970 HD
4 ddr2 sticks
4 SATA HDD (2 normal, 2 green)
1 dvd burner
5 USB devices
7 case fans
= 450W
that don't sound right. mobo minimum is 500W
Answer 8 years ago
The peak and 'average' power rating on stuff often has some squish room. 450 watts is what it will run full bogged down - having the overhead is a good thing.
For example, my dual gtx460 + oc i5 rig should draw 500+ watts, at the wall I measure 350 at full load. I upgraded from a 450 watt to a 750 watt psu because within reason, a 750 loaded to 300 watts is more efficient than a 450 loaded to 300. Staying away from maximums and having overhead is a good thing. a 950 watt psu is overkill for most anything :D
