122Views7Replies
Author Options:
volatage booster Answered
Hi every one . i need to know if its possible to boost DC voltage from 0.1V source to 3.8V DC output and how to do it  thx for answer :)
Franks Instructables
One of my projects that I have on instructables is capable of boosting .3 volts up to a number of volts using a DC to DC converter. The clincher is using old fashioned Germanium transistors which can be quite expensive.
Downunder35m
Downunder35m
5 years ago
Simply forget it, won't work.
Too lazy to explain all the reasons, if interested ask Google.
Toga_Dan
Toga_Dan
Reply 5 years ago
Howzabout some keywords to google, Downunder?
Downunder35m
Downunder35m
Reply 5 years ago
low input voltage booster
Quite on top you see Texas instruments with 0.7V input.
0.1V is below the working voltages of standard electronics, whatever you use the losses will be higher than the input.
Toga_Dan
Toga_Dan
5 years ago
What are you using? Lemons + coins?
steven4872
steven4872
5 years ago
DC to DC converters do this. However to do it you need transistors that work a 0.1V. Most transistors require a higher voltage to operate effectively. As a result most DC to DC converters stop working when the voltage drops below one volt. About the only way you could do this is to power the DC to DC converter with a seperate voltage source (a battery) and it would then take the 0.1 source voltage and increase it to 3.8V. But then you run into a new problem. 0.1V source is probably very low power. The DC to DC converter can increase the voltage but it cannot increase the power (Watts) available (in fact you will likely loose some power. You may not have enough power to do anything practical.
Toga_Dan
Toga_Dan
5 years ago
The simplest way is to have 38 of your 0.1V sources in series.
When I've wanted to boost low v DC sources, I've done a chopped DC waveform produced by a capacitor charge/discharge circuit. This chopped DC can be fed to a transformer. I don't know about running this with so low a voltage, tho.
