2810Views2Replies
Author Options:
waterproof nontoxic adhesive? Answered
I'm looking for an adhesive that will bond plastic to plastic, is waterproof, and is also non-toxic. I am attending an "anything but cups" party and am planning to use a Magic 8 Ball. I know that there is a canister inside which holds the die and blue liquid. I believe in order to take that out, I need to open the entire ball. I don't think that it will snap back together in a way that won't leak. Any suggestions would be appreciated!
caarntedd
caarntedd
10 years ago
Polyurethane sealant? You might want to research a bit yourself though. All I know is that it needs to be properly cured before you use it, alcohol might affect it, and I'm not dead yet.
RavingMadStudios
RavingMadStudios
10 years ago
Pop off the window with a screwdriver, drain the liquid, then use a Dremel to cut  & grind away the cylinder from the inside, while leaving the ball itself intact.
OR
Do it like this:
http://8ball.ofb.net/howto.html
