118Views21Replies
Author Options:
what about minidisc? Answered
does anyone have any clue as to how you could take minidisc components and somehow add them to a computer? i have an old sony portable MD player that i ripped apart and was curious as to why no one has tried this? there must be a way to do it because i thought i remembered there being an old Sony VAIO that had a built in minidisc drive on the fron of it. maybe i am mistaken, i dunno, but please let me know if there is any way of doing this! thanks!!
NachoMahma
NachoMahma
13 years ago
. Well, in theory, if you can hear it, you can get into the computer. . You can probably adapt a drive-bay mounting kit to work. If the MD player is a top-loader, you're gonna have problems mounting it in a computer so that you can insert/eject discs. . My Walkman MD recorder (MZ-R37) has an optical S/PDIF port that I use to dub from my CD changer. IIRC, the port is bi-directional. I've seen S/PDIF cards that should work. This will give you true digital. . It also has a "line out" jack that should work with just about any sound card. Very hi-fi, but probably not as good as S/PDIF. . You should be able to use the headphone jack with a sound card, but that may require some impedence-matching that is beyond me. . The manual should tell you what output options you have. You may be able to find the manual on Sony's web site.
cameraguy1976
cameraguy1976
Reply 13 years ago
aside from the obvious, i was trying to figure out if it could be wired into the computer just the same way any other optical drive could be. it has ribbon cables for the purpose of transporting data and power, so if someone knew how to get the schematics on any type of minidisc player, maybe its possible to rig it so you can use the minidisc the same way you would use a cd or dvd drive? thanks for the comment!
NachoMahma
NachoMahma
Reply 13 years ago
. If the ribbon cable is (E)IDE, it should be a snap. . Try Sony's web site. I don't think you'll find a schematic, but you may be able to ID protocols/power requirements/etc.
cameraguy1976
cameraguy1976
Reply 13 years ago
the thing about it is, the reason why i came here is because i am not smart enough to figure out how to do it on my own, so i am hoping with the help of the smart people here that it can be accomplished, lol! unfortunately, the ribbon cables i referred to on the minidisc device are not IDE type cables. they are the same type you will find in any other optical storage device. the ribbons are small and stiff and slide into a holder colored grey or brown.
NachoMahma
NachoMahma
Reply 13 years ago
. Tell you what, make an effort to find what you need on Sony's site (I think you're smart enough); if you're still lost, post the model number and I'll see what I can figure out. Deal?
. I don't mind helping you out, but this is a DIY site. ;)
. I don't understand your description of your cables. I can't remember seeing an optical drive that didn't use IDE. What am I missing?
cameraguy1976
cameraguy1976
Reply 13 years ago
sorry, i know i wasnt specific about the ribbon cables, i was talking about the internal ribbon type cables, not the external ones that are 40-80 pin. if someone could build the circuitry for an adapter that could go from the laser of the minidisc device and be converted to IDE, then maybe it could be tweaked to use the minidisc as a data device. let me know what you think and i will try to do the research for it.
lemonie
lemonie
13 years ago
What's the capacity of your minidisc? L
cameraguy1976
cameraguy1976
Reply 13 years ago
i have the 74's and the 80's
NachoMahma
NachoMahma
13 years ago
. BTW, if I understand what little bit I know about MD, you won't be able to use it for data storage.
