64Views7Replies
Author Options:
what are the domains in which an avr microcontroler can be useful to make an electric car.? Answered
Nr-Think different
Nr-Think different
9 years ago
well im confused about the choosing of microcontroller.The jobs assigned are Lighting, battery indication,speedmeter.And the car is electrical and should be able to drive by the 2 persons sitting at the front at one at a time.i dont know whether it is possible to do controling with microcontroller for that purpose!The steering part seems to be complex one.
Nr-Think different
Nr-Think different
Answer 9 years ago
im adding the info that both persons at the front must be able to drive w/o changing the seat one at a time
bwrussell
bwrussell
9 years ago
It sounds like you may have something specific in mind. If you can tell us what that is you will receive better, more specific help.
Nr-Think different
Nr-Think different
9 years ago
so in order to increase the complexity or wide range of working areas what should be done.should it be replaced by a microprocessor .
mpilchfamily
mpilchfamily
Answer 9 years ago
Well consider what kinds of things you may want to monitor or control in the car. You can use a micro controller to monitor the motor temp and battery charge levels. It can be used to help actuate controls for heating and air. If your not going to use the original car's control system then you will need a way of controlling lights, monitoring speed and RPMs. Anything a cars typical control system needs to monitor a micro controller might be able to do for you. Just keep in mind the limitations of micro controllers. They can't do everything.
mpilchfamily
mpilchfamily
9 years ago
What do you mean by domains? Are you asking how a micro controller can be used in an electric car?
