260Views13Replies
Author Options:
what are the planets on the solar system? Answered
well the earth is the third planet from the sun. Pluto is also a planet but it is the smallest planet and coldest one to. Earth is between Mars and Venus.
mrmerino
mrmerino
8 years ago
For a really long time, astronomers thought there was a small planet between Mercury and the Sun, due to the discrepancies in Mercury's orbit and its predictions. It turned out that the problems were caused by general relativity- the mass of the Sun was distorting time and mucking up Mercury's orbit.
They called this planet Vulcan.
kelseymh
kelseymh
8 years ago
Pluto is a "dwarf planet" not a planet. I will leave it to you to complete your homework by finding out why.
steveastrouk
steveastrouk
Answer 8 years ago
Because the IAU SAID so, and it made a lot of astronomers cross too.
kelseymh
kelseymh
Answer 8 years ago
Yes, they said so. And they provided a rational (if arbitrary) definition, which had never existed before. Prior to the 2006 IAU decision, the term "planet" was not well-defined at all, and was assigned, removed, and reassigned essentially at the whim of the astronomical community. Look up the history of early asteroid discoveries, for example.
steveastrouk
steveastrouk
Answer 8 years ago
What actually seems to have put the final nail in the coffin is the discovery of a bigger dwarf planet than Pluto, Eris,
kelseymh
kelseymh
Answer 8 years ago
Yes, indeed. That's the same thing that happened with the asteroids: originally, Ceres, Vesta, Pallas, and a couple of others were all being called "planets," with their own astronomical symbols and everything. Once about a dozen or so had been discovered, with an obviously large population still out there, astronomers basically said, "screw this," and came up with a different naming convention.
rickharris
rickharris
Answer 8 years ago
My definition - can I stand on it - will it: sake more than an hour to circumnavigate - if so its a planet (small) :-)
kelseymh
kelseymh
Answer 8 years ago
But that definition is incomplete -- circumnavigate at what speed? Low orbit? High orbit? Surface travel? With a human driver or with a robot rover? It also doesn't address any of the astronomical observational issues related to identifying a planet.
rickharris
rickharris
Answer 8 years ago
+1
Pluto, Mercury, Saturn, Venus, Earth, Jupiter, Neptune, Mars
However they are not in the right order - That's for you to research.
steveastrouk
steveastrouk
Answer 8 years ago
Pluto isn't......
Jack A Lopez
Jack A Lopez
Answer 8 years ago
Yeah. Pluto used to be called a planet,
http://en.wikipedia.org/wiki/Planet#Solar_System
but it got demoted after the discovery of half a dozen or so other rocks, now called trans-Neptunian objects (TNOs), that are similar in size, and orbit, to Pluto.  At the time of this writing, the Solar system is known to have about as many Pluto-sized TNOs as it does true planets.
I found a nice graphic, here,
http://en.wikipedia.org/wiki/File:EightTNOs.png
And the rest of the story is here:
http://en.wikipedia.org/wiki/IAU_definition_of_planet
http://en.wikipedia.org/wiki/Trans-Neptunian_object
http://en.wikipedia.org/wiki/Pluto
frollard
frollard
Answer 8 years ago
You forgot 'Glendor'
