170Views2Replies
Author Options:
what exactly is an adjustable speed drive and how to select one to make DC motor run with it ??? Answered
a mechatronics racing toy car that runs with variable speed .
firebird982002
firebird982002
11 years ago
Is this going to be manual or remote control? If it is remote control, look for an rc ESC (electronic speed controller). If you want it manual, to controls the speed is to control the flow of current to the motor. The easiest and cheapest way to control the current is using a variable resistor, known as a potentiometer. Potentiometers are measured in terms of resistance known as Ohms. They also are measured in how much power they can allow to flow through them in Watts. So, if you have a little tiny micro motor, you would need a 1 watt potentiometer. If you have a huge thumb sized motor, you would need a 15 or more watt potentiometer. Keep this rule of thumb, you can never use too big of a potentiometer, but you can use a too small of one. For example, you can use a 15 watt potentiometer on a micro motor.
pavan5859
pavan5859
Answer 11 years ago
thanks alot for the suggestion firebird ...but is there any other way by which we can manually set the control of current flow like the speed of motors keeps changing once the toy racing car is set in ON mode . even if it can be remote control or any other way ......please suggest
