3717Views2Replies
Author Options:
what i can use to replace MPF102 ? Answered
hello , i making the little gem mk2 (http://www.runoffgroove.com/littlegem.html)
the problem is i cant find any jfet mpf102.I have some other transistor, witch i can use to replace the mpf102 ?
2n3904
2n3906
2sa1015
2sb564
2sc1815
2sc2222
2sc945
s8050
s8550
s9013
s9014
s9018
thanks!
steveastrouk
Best Answer 7 years ago
If you're not after a very high input impedance, try a BJT instead of a Jfet.
JeffryH
2 years ago
I'm also looking for a MPF102 substitute. MPF102 is a N-Channel depletion mode transistor - many of the transistors you've listed are NPN or PNP bipolar, and those won't work as replacements. The 2N5486 has similar specs and the same package and pin layout as the MPF102. Digikey has it list for a buck and change in low quantities, so I'm going to try it. Their part # is 2N5486CS-ND.
