111Views6Replies
Author Options:
what if i use household materials to "carry hydrogen and oxygen on its normal state? Answered
What if i instead of using expensive materials and building cryogenic systems to store oxygen and hydrogen...
   I use electrolysis to separate oxygen (Negative) and hydrogen (positive) from water and store it in a water bottle so that i have a portable system of hydrogen and oxygen so that i can use it a few minutes after its "extraction".
rickharris
rickharris
Best Answer 8 years ago
Yess... I say with caution, of course you can store gas in a bottle - Generally captured over water to make sure the gas isn't contaminated.
I am assuming your water bottle is empty?
Your not going to get much gas without compressing it though - Depends on what you want to do with it.
jamesc4
jamesc4
Answer 8 years ago
The bottle is empty only for the oxygen.
Thank you for the help :D
iceng
iceng
8 years ago
That is actually a great way to do it !
Also you avoid storing Hydrogen..
Hydrogen is a single atom which leaks from any pressure container
devised by man..  It Hy  is sliding between the empty spaces in the metal cylinder atomic structure  used to contain it.......
A
jamesc4
jamesc4
Answer 8 years ago
Thanks for the help :)
AndyGadget
AndyGadget
8 years ago
Absolutely no problem at all.
The reason cryogenic storage is used is that oxygen gas at room temperature / pressure will have 848 times the volume of liquid oxygen.  For hydrogen it will be 860 times more.
Pressurised storage is also used, but a much greater volume can be stored when in liquid state.
jamesc4
jamesc4
Answer 8 years ago
I would like to thank you for giving the main ideia in the next topic i will be posting.
Thank you for your help :D
