Build yourself a winding machine, we used to use Erector/Meccanno. Don't try and run the wire off the reel by pulling the reel around, the wire will just snap. You need to make a vertical stand for the reel, with a "spinner" that takes the wire off over the end of the reel. I'll try and post a picture of our winder at work later, so you can see how it works.
ive thougt about what you said , with the wire being pulled of the reel sort of like a single phase welder but a bit faster . with the other motor fully adjustable to the speed of reel as it loads the coil
Best Answer 10 years ago
Answer 10 years ago
Thanks for the reply it sounds interesting,
10 years ago
Answer 10 years ago
No, NOT like a welder - I'll get you a picture - over the EDGE of the reel, because pickup wire is way too thin to pull on Steve
