what is the equation i should use to dilute 50% hydrogen peroxide into lower concentrations?
hello, i just got some 50% hydrogen peroxide, from my local pharmacy because they were out of 35%, plus for some reason 50% is free.
anyways, i want to know whats the equation for finding out how many ml's of water i need to use to dilute a solution toa certain amount, as i want to use the 50% peroxide to make 30% , 22% and 3% peroxide.
now ive looked on google and i couldnt find a thing , and if i did by chance come across it, i didnt understand it.
what i want to know is how much distilled water will it take to convert 100ml of 50% hydrogen peroxide to the above concentrations, or if possible, could someone please give me the equation for converting any concentraion to any, please!
also, whoever answers my question and solved my problem entirely will get a best answr i promise!!!
Best Answer 10 years ago
Since you have a 50% mixture of hydrogen peroxide, that is the highest you can go (without adding more hydrogen peroxide)... so given your 100ml... you have 50ml of hydrogen peroxide and 50ml of water... so the equation you have is...
50ml (hydrogen peroxide)/(100ml + added water) = percentage of hydrogen peroxide
Water to add (ml) = (50/Required percentage) - 100
So 30% you add... 66.6ml = (50/0.3)-100
For 22% you add... 127.3ml = (50/0.25) -100
for 3% you add... 1566ml = (50/0.03) - 100
Reply 2 years ago
I need to make 3% hydrogen peroxide mix out of the %50 hydrogen peroxide i have. I need this equation for a 50gallon mix... could you help me?
10 years ago
I've never heard of a pharmacy carrying 50% H2O2.
The concentration is a direct ratio. If it is indeed 50% then you need to figure out how much peroxide there is in a given amount of concentrate (divide by 2) and then figure out how to make a different %.
100mL of H2O2 has 50mL of the magic juice.
If you want 3%, you need to add water inversely (cross multiply)
Answer 10 years ago
the pharmacy doesnt, they orderd it in from a company that mass produces it and has offerd to locally sell it for use in rockets and stuff like that , though the pharmacy was able to aquire 500ml for me instead of 25l
11 months ago
What i use for stabilize to hydrogen peroxide ?
1 year ago
Hi! The way I calculate the dilution of HP. If you have a 50% HP it means that 50% is water. If you want to make a 3% dilution / strength - you multiply by 6. i.e. HP 50% X 6% = 6ml ... then you add 94% water which is 94ml. Voila - you have 100ml of 3% HP!
10 years ago
will this equation work for any amount of peroxide?
as in if i were to use 10ml, proportionally it should be the same, right?
Answer 10 years ago
The equation above is for 100ml so for 10ml divide by 10...
But if you want...
Water to add (ml) = (ml of hydrogen peroxide)/Required percentage) - (ml of total liquid)
so for 10ml...
For 30% you add... 6.6ml = (5/0.3) - 10
For 22% you add... 12.7ml = (5/0.25) - 10
for 3% you add... 156.6ml = (5/0.03) - 10
Answer 9 years ago
your explanation is good but still am confuse can briefly explain what is added mention name
my question
" I have 50% h2o2 and make 10,20 ,30 % H2o2 plz send immediately,I hope positive response urgently
Answer 9 years ago
What on earth is a "added mention name"?
Answer 10 years ago
ah, thanyou, i understand now
