Motors are inductors, if you pump energy into them you store some of it as magnetic-field. If you stop, the field-collapses and the inductor tries to spit the energy-out in the opposite direction. On a motor-commutator this can cause arcing (sparks) which generate broad-spectrum radio (it interferes with TV, Radio, Phones, etc). Like Steve' said Its a "suppressor" it helps stop radio interference, because it conducts the energy without arcing. Capacitors don't conduct DC, but if polarities are switching they will conduct.
Its a "suppressor" it helps stop radio interference being generated by the motor. In fact, its usually better to put a resistor and capacitor in series across the motor, and what looks like a cap is actually an RC network.
Best Answer 10 years ago
L
Answer 10 years ago
. This may be picking nits, but caps don't conduct, they store.
Answer 10 years ago
Yes, but they also discharge. AC goes through them.
L
Answer 10 years ago
. Electrons go in and electrons go out, but electrons to not go through. Ever see an ampacity rating for a capacitor?
Answer 10 years ago
Strictly speaking AC carries no (net) current in either direction, so you might argue that copper doesn't conduct AC either?
L
Answer 10 years ago
. In a cap, the electrons go in and out at the same point and don't travel through - think inflating/deflating a balloon.
10 years ago
Aren't caps also used over motors to improve power factor?
Or does that only apply to big AC motors?
10 years ago
It may serve several functions. Listed in order of expectation.
1. If it's an audio device it us usually there to filter out rf interference created by the sparking of the brushes of a dc motor.
2. Or it may be there to kill the inductive spike caused when the motor turns off.
3. If it's an ac motor it is a starting capacitor that helps the motor start and then gets turn out of the circuit.
10 years ago
