1119Views7Replies
what is the turn ratio for a 220v to 36v transformer?
I've a transformer core like a MOT(tall but slim) and i want to make a power supply for my zvs driver with it. so what should be the number of turns on the primary and the secondary if the input voltage is 220V AC and the required output is 36 v (min 10A). also what should be the gauge of the wires to be used for winding.
Best Answer 7 years ago
about 6:1
220/36
There will be some losses in the transformer - depending on how well you make it possibly a lot (you will see this as heat).
MUCH easier to buy a suitable PSU.
Answer 7 years ago
i've got a psu but a psu give out just 12v, i'm looking for a much better power supply.
Answer 7 years ago
i've once read in a site that you can connect PSUs(SMPS) in series to get a higher voltage, is it possible?
Answer 7 years ago
Under certain circumstances, that the outputs are floating, yes.
Answer 7 years ago
is there a problem if the wattages are different for the two smps?
7 years ago
You are limited to the maximum current of the lowest rated supply, but the voltage will be increased by the sum of the output voltages. So if you have a 12V 1A supply, and you connect a 24V 10A supply, you can only safely consider it a 36V 1A supply.
Answer 6 years ago
what if i parallel connect em? then the voltage gonna be 24 v and the current 10 +1 A.. am i right?
