251Views12Replies
Author Options:
what is the use of a petrol in a generator? Answered
the major function of petrol and the passage of the petrol in a generator
AGTx
AGTx
4 years ago
Every generator needs a fuel to generate electricity it usually use coal, petrol or diesel. Most of the generators (usually electrical supply plants) use these fuels (mostly coal and diesel) as a source of heat to make water to steam then this steam is used to rotate the turbines and through the dynamo it produces electricity.
Or if it is a usual small generators used to only supply electricity to one house it uses the concept of internal combustion and here only petrol is used.
iceng
iceng
4 years ago
There are also rotary generators that are powered by ;
Animal, Hand, Water, Wind, Steam and anything the mind of a human can contrive !
rickharris
rickharris
4 years ago
Unless the generator is powered by a gasoline engine it has no use in the generator it'self.
seandogue
seandogue
4 years ago
It depends on the generator being powered with the gasoline, as well as it's average load. You can contact the generators' mfg to determine average and peak consumption rates based on usage
petercd
petercd
4 years ago
The petrol in the generator is the happy liquid.
When there's a power failure and you have the happy liquid you'll be dancing with the lights on but everybody else will be sitting in the dark, sadly staring at candles.
Its hard to put on a happy face and dance a lively jig with candles.
steveastrouk
steveastrouk
Answer 4 years ago
But don't do the lively jig with candles NEAR the happy liquid.
iceng
iceng
4 years ago
Petrol is liquid electricity.
A generator converts the liquid to AC current.
Just as grape wine is liquid sunshine.
Vyger
Vyger
4 years ago
petrol in a generator serves as a memory aid and training mechanism. For example, when the lights go out and you then remember that you forgot to put more fuel in it. Or when the electric service goes out and you find that your tank is empty because you neglected to service your emergency equipment in a timely manor.
rickharris
rickharris
4 years ago
I don't understand. sounds like an odd homework problem.
Downunder35m
Downunder35m
4 years ago
I refer to Google assuming another pre-teen....
