77Views7Replies
Author Options:
what is the value that obtained from serial monitor in arduino?? ? Answered
I working with my DIY sensor ( colour sensor) and i have no idea what the reading i obtained from the serial monitor in arduino software ? Anyone know? and how to change the value to voltage value? as i need to write down the voltage reading for my result part.
rickharris
Best Answer 2 years ago
The analogue to digital converter (adc) will change an analogue value (voltage) into a digital number.
Depending on how many bits are involved it will split the max value up by that number of bits
So if you max value is 5 volts and your measuring it to 8 bit accuracy that means the 5 volts will be split into 255 (8 binary bits) sections each equal to 5/255 volts. simple maths will give you the value you need once you know how many bits your ADC uses.
OngE2rickharris
Answer 2 years ago
thankyou sir, do you know the way to connect my value to Visual Basic? i need to interface VB with arduino :)
steveastroukOngE2
Answer 2 years ago
Never written for it, but IIRC, you open a "file" to the "file" COM1 or whatever.
steveastrouk
2 years ago
Looking at your numbers
Voltage = number received * 5/4095 where the 5 is the reference voltage to the ADC and 4095 is the number of bits in your number
Which arduino are you using ? The basic one had an output that would only go 0..1024
OngE2steveastrouk
Answer 2 years ago
the number received ... every time the number gt three readings which are Red , Blue and Green. which number should i take ?
steveastroukOngE2
Answer 2 years ago
All of them ! The colour is encoded in the return from all three channels.
Red volts= red number*5/4095 etc
OngE2steveastrouk
Answer 2 years ago
thank you very much . helped me alot :)
