76Views5Replies
..what kind of battery should i get to run for a 16 mile bike ride??
I have installed a motorcycle headlight to my beach cruiser..and was thinking of getting blinkers for it too..im just stuck on battery..
5 years ago
Hey thanks for Feedback !! this what i found..its got high and low beams..ive been told i might want to change the light bulb...but why did they put the one there on the first place..dunno!!..but ill take direction..just want to get this thing working!!..thanks People!
Specification:
Answer 5 years ago
You need a battery that will supply at least 3 amps for say 2 hours.
I suggest you look at the lithium batteries used for RC aircraft, a 4 cell will give you around 12 volts.
NOTE you will also need a suitable charger for this type of cells. They can be dangerous if not charged properly
Alternatively a small lead acid battery perhaps for a motor bike should be OK.
5 years ago
Is that an incandescent lamp? Replace it with LED's and it won't be a problem
5 years ago
If you did not use LED's for the job you might need a trailer for the battery.
So as with most request here: Make sure to provide the details people need to answer your questions as our crystal balls are getting hazy from overuse.
5 years ago
You, and we, need to know the wattage of the lights OR the current drawn.
Likely this is on a lable or the box the light came in.
Tell us more and we might have a better idea.
