123Views6Replies
Author Options:
what kind of experiment could be made to measure the speed of light (with a laser for exemple)? Answered
kelseymh
kelseymh
11 years ago
Use a chopper and a mirror.  Mount a toothed wheel (count the number of teeth and gaps) on a motor where you can control (and measure!) the RPMs.  Aim your light (laser pointers are nice) through the chopper at a mirror far away (measure the distance!).
Stand directly behind the setup, looking at the mirror through the chopper.  You should see the laser spot reflected back at you.  With the motor off, or going very slowly, the light goes through a gap, reflects and comes back through the same gap.
Now start turning up the motor speed.  At some point you won't see the reflected spot any more.  The motor is spinning just fast enough that the gap moves away from the light beam before it gets back to you; the beam is blocked by the adjacent tooth.
If you know the tooth spacing and the motor speed, then you can calculate the time interval between a gap and the adjacent tooth.  Since you know the round-trip distance (from the wheel to the mirror and back again), you can calculate the speed of light.
With this set up, you should be able to get a 10% measurement.
Re-design
Re-design
Answer 11 years ago
I like this method.
Jayefuu
Jayefuu
11 years ago
How about this?
http://www.thenakedscientists.com/HTML/content/kitchenscience/exp/measuring-the-speed-of-light/
(I found this in a few seconds with google)
steveastrouk
steveastrouk
Answer 11 years ago
Which is great, but it requires an ACCURATE frequency measurement, begging the question really.
Rœmer's method is elegant, if slow....
Steve
Re-design
Re-design
Answer 11 years ago
You know, I've seen this before.  There is an instructable that uses chocolate instead of butter.
P.S. Don't tell too many people about Google.  If everybody used it then I'd have nothing to do all day and I'd have to find some other site to watch.
