80Views12Replies
Author Options:
what tumbler can i use to polish up or smooth my 3d printed creations? Answered
i was wondering if there was a tumbler of some sort that i could purchase to smooth or put a finer touch to my 3d printed objects
3DeanPrint
3 years ago
my prints are as good as can be my settings i have messed around with and found out what i need to produce the best prints but id like a tumbler to give them that extra cleaner look. does anyone a desktop version or any makes of tumbler that are worth looking into? thanks for all your help.
steveastrouk
3 years ago
PeterCD's method is very effective, but vapor-phase polishing in acetone is even better, where you heat the acetone, and sit the part in hot vapour.
petercdsteveastrouk
Answer 3 years ago
It has a flashpoint of -20 degrees C, which is why I mentioned the cold vapour bath only.
Best to use a double boiler if one wants to try the fast track brave route using heated acetone.
icengpetercd
Answer 3 years ago
I use acetone at room temp which is way above the -20C flashpoint....Can you explain ??
petercdiceng
Answer 3 years ago
Basically its a level of safety that you're comfortable with, I dont have a problem with room temp acetone, I use it in the garage and house, but I dont heat it up to 80deg C like one does with a smoothing vapour bath.
Wiki source
At temperatures greater than acetone's flash point
of −20 °C (−4 °F), air mixtures of between 2.5% and 12.8% acetone, by
volume, may explode or cause a flash fire. Vapors can flow along
surfaces to distant ignition sources and flash back. Static
discharge may also ignite acetone vapors, though acetone has a very
high ignition initiation energy point and therefore accidental ignition
is rare.
steveastroukpetercd
Answer 3 years ago
Very true. We didn't use an open flame, but a hot plate outdoors.
iceng
3 years ago
Polish tumblers remove material...
petercd
3 years ago
If you're using ABS you can use a cold acetone vapour.
http://makezine.com/2014/09/24/smoothing-out-your-3d-prints-with-acetone-vapor/
Downunder35m
3 years ago
First it would help to know or see what you mean by polish.
If you need a lot of cleanup to get a good looking part you should start by optimising your print settings first.
I usually only clean up the brim and the support material but not the surface of my prints as it is not required.
