1490Views20Replies
Author Options:
what type of current flows in the starship coil and in which amount ? Answered
i want to know that what kind of current is flowing in starship coil because it has winding of naked copper wire so if we give any supply than how it will work?
Josehf Murchison
Josehf Murchison
7 years ago
Federation, Klingon, Romulan?
They all don’t use copper the plasma conduits are made of transparent reactive biopolymer magnets, much like the flexible magnets on your refrigerator door.
When plasma is present in the conduit it polarizes the electrons in the conduit like a capacitor creating a field to contain the plasma there is no current flow in the conduit itself.
Now copper coils will do in a pinch creating a magnetic field by current flow through the copper coils however reactive biopolymer magnets are much more energy efficient.
Joe
iceng
iceng
Answer 7 years ago
That is very much like our own ionic nerve propagation.
A
Josehf Murchison
Josehf Murchison
Answer 7 years ago
Yes it is very much like neural biology.
Did you do know Star Trek technology is based in real theoretical physics.
That is why I tell people if they just want a basic understanding of physics read SiFi it is just as accurate and it is more entertaining than a textbook.
This is also why SiFi writers like me watch our BS our fans tend to tell us when we get it wrong.
Larry Niven made that mistake in Ringworld, in the first printing of Ringworld he rounded off the acceleration of Earth’s gravity to 10 meters a second from 9.80 meters a second just to make the math easier to do. 9.80 meters a second being an absolute number denoted by ending in 0 you should never do this. Well his fans let him know he made a booboo.
In the second printing he commented on the flak from his fans saying he was a writer not a Theoretical Physicist and he was not going to rewrite the book for one little math error.
In the third printing he rewrote the book.
I was cleaning my lab the other day look at what I found.
Joe
shomas
shomas
Reply 2 years ago
Acceleration due to gravity changes by location. Decades ago i learned a fun little fact, that in Saint Paul Minnesota USA, G is roughly 9.80597 meters per second^2.
iceng
iceng
Answer 7 years ago
Niven wrote wonderful books
  • Fleet of Worlds
  • Known Space
  • Ringworld
  • The Smoke Ring
  • The Mote In God's Eye
Are some favorite  SiFi novels i can fondly recall ....
Josehf Murchison
Josehf Murchison
Answer 7 years ago
I have read a lot of his work also.
Isn’t it funny how the movie is never the same as the book.
Joe
iceng
iceng
Answer 7 years ago
What movie ? !
of Niven ?
Josehf Murchison
Josehf Murchison
Answer 7 years ago
Not just his work but other writers also.
A few of his stories have been adapted for TV like Inconstant Moon on The Outer Limits and The Soft Weapon adapted for Star Trek.
Joe
iceng
iceng
Answer 7 years ago
Oh ... Iv seen many Outer Limit etc.
Even bought a ringworld game which was hideous room to room crawling
No moving about`except the book path.
Left it after a 1/4 of the trip.
Yea  ....  the movie or game is never the same as the book.
mpilchfamily
mpilchfamily
7 years ago
First of all you don't use bare wire to make a starship coil. You use magnetic wire which has a thin clear plastic coating on it so you can make tight coils without them shorting.
If you want to know how much current the coil will draw then use Ohm's Law (I = V / R). Take the voltage from your power source and divide that by the resistance of the coil. So you won't know till you have made the coil. The length and diameter of the wire will dictate the resistance. The larger the coil is and the more turns you use on it the higher the resistance.
shomas
shomas
Reply 2 years ago
Ohm's Law (I = V / R) works for direct current. All current paths create magnetic fields storing some energy in the field. When the current is reduced the magnetic field collapses releasing some of the energy that was stored. Alternating the current dirction stores energy again in a reversed magnetic field and the cycle repeats. That is the basics of inductance. It is measured in henries in formulas it is represented by the letter L. Coils have more turns and can store more energy in a magnetic field. Alternating a current through a coil gives rise to something we call inductive reactance X(L) =2×pi× freqency× inductance. Inductice reactance impedes the flow of alternating currents simular to resisters and is measured in ohms, but where resisters convert the energy to heat by watts=volts×volts/resistance reactance absorbes and releases energey back to the circuit. There is a property of capacitors in ac circuits called capacitive reactance X(C) the total reactance (sometimes called X), in a circuit is X(L) - X(C). Then there is a propery called impedance denoted as Z = sqrt( resistance^2 × ( X(L)-X(C) )^2). The average current then is Amps=Voltage/Z. This means that aside from resistance inside a length of copper wire, alternating current through a coil is restricted by both the freqency of alternating current and the inductance of the coil. There are other effect on current through a coil such as skin effect at high freqency and capacitance between turns on a coil. Google if needed.
nerd7473
nerd7473
Answer 7 years ago
cool! I used enamel coating on mine
iceng
iceng
7 years ago
NOT NAKED but ----
Insulated copper motor magnet wire and
there is 7 cycles AC sinusoidal current flowing through your coil
from an audio amplifier using a signal generator for the input.
This is a non-iron non-air-gap AC motor stator winding (see picture),
known to electrical engineers in every country with AC power.
If a second star winding is placed at an angle to the first and
another 7 cycle AC current is passed through this second coil but
phased by a a quarter cycle then
the magnets will begin to rotate............ A
iceng
iceng
Answer 7 years ago
This is the MAD SCIENCE  Rodin starship coil experiments. video
I make reference to in the above comments ...........
nerd7473
nerd7473
Answer 7 years ago
I was wondering is there a easy way to make a starship coil spin a magnet at a very high rpm? Like using a brushless fan circuit?
Kiteman
Kiteman
7 years ago
Nurse, we need IV tinfoil, stat!
rickharris
rickharris
7 years ago
I see I have unwittingly entered THAT part of the internet again!
Vyger
Vyger
Answer 7 years ago
The Fringe area of the Twilight Zone.
Vyger
Vyger
7 years ago
It's copper surrounded by transparent aluminum so you can't see some of the critical components because they don't reflect light. As far as a current its positronic current which is the same that is used in the artificial brains of the robots. (Positronic processors)
framistan
framistan
7 years ago
Have you forgotten your reactor theorems so soon after graduation? It is a Pulsed DC waveform of INFINATE Amperes for one microsecond. Any more than that would rip apart the fabric of space!
