198Views13Replies
Author Options:
what will happen if i give dc 12v and 5 ampere to 2000watt inverter , how much ac ampere should it produce ?? Answered
i now what inverter does it convert dc to ac , i also know that it can convert dc 12 volt to ac 120 -110 volt but  the thing from which i m confused with is that what will happen to the ampere for example i have a 12 volt 5 ampere battery if i plugged the battery to 2000 watt inverter should it produce 2000 ac watt with just 12 volt and 5 ampere battery or i have to give more dc ampere to the inverter................ means can inverter    convert dc less volt to ac high volt  and  with also convert dc less ampere to ac high ampere   or will it convert  dc low volt to ac high volt without changing the dc low ampere and need more dc ampere or will it convert dc low volt to ac high volt with decreasing the dc ampere....
iceng
iceng
Best Answer 5 years ago
A 12V 5A battery can deliver a maximum of 12 x 5 = 60 Watts.
If your inverter is a good one 85% efficient and works at all, it will deliver 115VAC
Current = ( Watt / 115v ) x o.85 = 60/115 = o.52A x o.85 = o.44 AC Amperes
iceng
iceng
Answer 5 years ago
Why would you click me a Best Answer and take it away ?
Josehf Murchison
Josehf Murchison
Answer 5 years ago
I hate that, I wrote:
Not much since you are putting 60 watts into a 2000 watt circuit.
A fast and dirty answer.
If you think about it might not even have the power to run the circuit at 80% efficiency.
iceng
iceng
Answer 5 years ago
Ahaa well, it happens several times a year with newbies.
Have a nice week Josehf.
BurningMan has started, As a qualified Ranger I'm not paying $800 for desert survival :-(
Josehf Murchison
Josehf Murchison
Answer 5 years ago
I wouldn't pay $800 for a survival class.
I grew up in the bush First Nations boy I am.
The first time I took a load down to Laredo Texas and had to go down for the weekend, a pain in the backside. So I went up north to Encino Texas north of the checkpoint to spend the weekend. Every time I went down there I spent the entire weekend eating cactus and walking in the desert and explaining to the border patrol I'm not an illegal.
It was wonderful.
iceng
iceng
Answer 5 years ago
Maybe you could have them send you back home North, on their ticket :)
I never went South of Las Vegas. My only memory was delivering a large keno display of my manufacture, standing and protecting it in the back of a truck. It the ambient street temperature was so Very Hot that I had to keep turning a different cheek to face the Hot Wind burning my face !
Josehf Murchison
Josehf Murchison
Answer 5 years ago
I had a load customs messed up the paperwork So I couldn't deliver it and I couldn't take it back to Canada ether it sat on the truck for a week until the paperwork cleared.
MuhammadK19
MuhammadK19
Answer 5 years ago
SORRY SIR I JUST CLICKED YOUR ANSWER THE BEST BY MISTAKE
ALTHOUGH YOUR ANSWER IS GOOD....
iceng
iceng
Answer 5 years ago
You are a fair man..
rickharris
rickharris
5 years ago
Power out = power in - losses
Watts = Amps x Volts
egarci06
egarci06
5 years ago
It depends on the design of the inverter. A 2000 watt inverter can produce up to 2000 watts IF the power source (the battery) can keep up. Clearly a 5A battery cannot. If you plug in a phone charger or some other low current device, it should work. The AC device plugged in should probably be 30W or less. Anything greater will probably cause the 12V input voltage to "sag" because it can produce enough current. A well designed inverter should detect this and shut down,
Note that the 2000 watt rating has nothing to do with this question. That is simply the maximum load the inverter can handle. In your case the limiting pactor by far is the battery output capibility.
MuhammadK19
MuhammadK19
Answer 5 years ago
SIR I KNOW THAT 2000WATT HAS NOTHING TO DO WITH THIS QUESTION , I KNOW THAT I COULD USE 3000 WATT , 6000 WATT ETC ... I JUST USED TERM 2000 WATT JUST AS AN EXAMPLE .... AND THANK YOU
Josehf Murchison
Josehf Murchison
5 years ago
MuhammadK19
MuhammadK19
Answer 5 years ago
THANK YOU SIR
