51918Views21Replies
Author Options:
what would happen if you mixed type 1 Portland cement without sand and gravel? Answered
frollard
frollard
Best Answer 11 years ago
sand and gravel are the 'strength' of cement in the right proportions. Too much and it will be crumbly (not enough butter for the bread), and too little you'll end up with 'all glue' - which more watertight, but less strong.
vince 09
vince 09
Answer 11 years ago
and just to add on to what you said concrete has a very high compression strength but no tinsel strength this is why they put re-bar in concrete
JaredL50
JaredL50
1 year ago
its 10 years later...and it still matters
What is the strength difference? If I make walking tiles out of cement VS if I put sand in it, which one will be stronger?
DonnaH184
DonnaH184
2 years ago
I use Portland cement and water no sand on a cinder block Grill I made it four years ago it's still standing strong I'm not sure what the long-term effect is but my opinion is at the Sand makes air pockets in the cement making it weaker, but sand gets you more for your money.
vince 09
vince 09
11 years ago
you would get cement not concrete, and I think it is kinda like plaster
frollard
frollard
Answer 11 years ago
cement is while its wet - after it chemically hardens it becomes concrete.
vince 09
vince 09
Answer 11 years ago
no cement, sand, and gravel, makes concrete when water is added. so if you don't put sand and gravel in it you will have cement. when concrete is wet it is just uncured concrete. I have worked with the stuff for two years now its not much time but enough to know that I am right. I don't mean to be rude so don't take it wrong I'm just stating the facts
frollard
frollard
Answer 11 years ago
I want to take your word, but that is not as I learned: From the Merriam-Webster Online Dictionary: CEMENT: "...a powder of alumina, silica, lime, iron oxide, and magnesium oxide burned together in a kiln and finely pulverized and used as an ingredient of mortar and concrete." CONCRETE: "...a hard strong building material made by mixing a cementing material (as portland cement) and a mineral aggregate (as sand and gravel) with sufficient water to cause the cement to set and bind the entire mass."
NachoMahma
NachoMahma
Answer 11 years ago
. hmmmmm All the cement defs I found with a Q&D search only mention dry product. I only saw water used with the word concrete. But, popularly, cement is cement with or without water; at least around where I live. But I've often heard concrete and cement used interchangeably around here, too. :) . Although it appears that technically cement is dry (I'm still not totally convinced), I couldn't figure out what else one would call cement with water but no aggregate.
frollard
frollard
Answer 11 years ago
the cement is what holds the aggrigate together - with or without aggrigate, once it hardents its concrete.
vince 09
vince 09
Answer 11 years ago
ya thats what I'm saying cement is a separate ingredient in the product concrete, concrete is a mixture of cement sand and gravel. I'm not saying what you said earlier is wrong I an saying you may have it misunderstood a bit. or I think we both have the same answer but just wording it differently.
NachoMahma
NachoMahma
Answer 11 years ago
. It looks like you and I are using common terms and frollard is using technical ones. Whatever's going on, it won't matter in 10 years. ;)
. What we've got here is, failure to communicate. LOL
vince 09
vince 09
Answer 11 years ago
nice lol and ya I do have a feeling we are trying to say the about same thing in different ways lol
frollard
frollard
Answer 11 years ago
no we're using different ways to say the same thing! :P
vince 09
vince 09
Answer 11 years ago
ya I was kinda noticing that. sorry about that
frollard
frollard
Answer 11 years ago
that same thing came to my attention ... apologies.
vince 09
vince 09
Answer 11 years ago
its all good at least we figured it out eh'
frollard
frollard
Answer 11 years ago
us being on the same page is a good thing.... Sorry - I cant stop parahprasing what you're saying - the same thing said differently....: )
vince 09
vince 09
Answer 11 years ago
no man its cool
caitlinsdad
caitlinsdad
11 years ago
I think you get something like grout but it wouldn't be strong if you are filling a large or thick gap. The aggregates(sand-gravel) are the ones that fill a gap and are bound together by the cement to make a strong block of concrete. Think of cement as just "rock glue".
