306Views12Replies
Author Options:
whats the best way to sharpen a knex rod? Answered
i want to sharpen a knex rod but it never ends up looking like for example gorkems rod in his video i tried sanding it down with a gear box and a drill to make it spin fast but the rod melts when it spins to fast so how can i sharpen a knex rod more effectivley
Tags:knex
shieldsam
shieldsam
10 years ago
use a lathe. extra fine, precision super-sharp rods.
Prranavan
Prranavan
11 years ago
i use pencil sharpener but i need to get an electric one coz pencil sharpeners do the job but it hurts ur hand a lot
~KGB~
~KGB~
11 years ago
pencil sharpner!
An Villain
An Villain
11 years ago
first i pencil-sharpen it (electrical not manual, manual sharpeners just aren't the right design, the blades may break) then i place it in a drill and spin it while grinding the head on a crank grindstone to get the pointy tip, it is very sharp and dangerous, have fun!
nutty guy
nutty guy
11 years ago
me I use a sharpener to start because if you just use the sharpener you will make it blunt then I carve away with a knife to make it sharp and when the rod gets blunt I re sharpen it with knife but be careful
knexsniper1
knexsniper1
11 years ago
i sharpen the knex rods in several ways. 1. use a pencil sharpener, the electric kind work better 2. use a filer for nails to erode the edges 3. use sandpaper 4 use an exacto-knife 5. very dangerous, (not reccomended) use an actual knife. hope this helps :) - Ksp
DJ Radio
DJ Radio
11 years ago
pencil sharpener is better than using a knife, the point is sharper, and its safer.
Killer~SafeCracker
Killer~SafeCracker
11 years ago
There are several different ways. I use a pencil sharpener but I have a few that are done on a grinder (they turn out like gorkems). I have also used a sharp knife and a file. I wouldn't use the knife because they are not as safe and the pencil sharpener worked better. So in the end I would use a grinder, file, or pencil sharpener. Hope this helps. K~SC
Yerboogieman
Yerboogieman
11 years ago
Pencil sharpener or Utility knife.
lemonie
lemonie
11 years ago
Use a sharp knife, like you were sharpening a pencil. It's a bit of a skill, but it's not that hard to learn. L
