Ah well the thing is, "glycol" isn't actually just one compound. The term glycol simply means a diol with the hydroxide groups on different carbons. The most common glycol is probably ethylene glycol, which is easily obtained from auto radiator fluid; usually a 50% solution with water (although some radiator fluid uses propylene glycol, and others contain neither).
Best Answer 11 years ago
8 years ago
I recently found some diethylene glycol (DEG) as FancyHeat food tray heaters, available at some dollar stores in the US.
11 years ago
You want to make something that self-ignites? I'm not answering the question, just guessing as to "why?" L
Answer 11 years ago
nope, smoke fluid :-)
Answer 11 years ago
Like this? http://www.bigclive.com/smoke.htm.
I found this site
L
11 years ago
I'm sure that you can find what you want here
https://www.spectrumchemical.com/OA_HTML/ibeCSrdSrchResults.jsp?cg=-200&kw=glycol&minisite=10020&respid=50577&ds=0&dr=50&st=kw&cpg=0§ion=10170&searchlov=-1&prodapp_pses=ZG4CA9BBF89C927DA885D54915EE2EB340FC6CDA4EFAA4EFDBFF2BD796B5652A70DC38A842BA54B8041F8FFC4C39ABA759562BACC4B138A99A&prodapp=ZH1tVbSspL9GnDI_4vLeeMr1%3AS
