3157Views1Replies
where can i get my psp fixed?
my psp 3000 dosnt charge. i need to get it fixed but i dont have much money to spend, can anyone point me in the right direction.
Best Answer 11 years ago
Normally it's the fuse that do that, it happened to me when I used an 9 volt battery to charge it, you probably used an unofficial charger and it accidentally blown the fuse inside. You can try to charge it from the USB port (Connected to a computer), but if it don't work it's probably both fuses that blown.
Normally you should be able to bridge that fuse without needing to open your PSP. It's the fuse number one in the picture that you need to bridge with a soldering iron, this is near the battery connector. If you don't want to do that you can buy a standalone battery charger too.
