467Views36Replies
Author Options:
which is more efective in a k'nex gun? one thick rubber band, or a few thin ones? Answered
~KGB~
~KGB~
10 years ago
one thick one, i had 1 thick one for 6 months on guns and i stilll have it today!
NYPA
NYPA
10 years ago
Doesn't matter. The thickness doesn't affect the range. The LENGTH does. For example, a thin 64 is just as good as a thick 64. But thick ones will be stronger.
Super Shooter
Super Shooter
10 years ago
Thick rubber bands work better.  They do not break as easily and are harder to streach so they have more power.
Fred the Penguin
Fred the Penguin
11 years ago
it depends on the gun and situation in a knex war one or two thick ones are best as they are easier to replace but for really massive shots use some small ones and add more after the pin is pulled back this is my secret to getting massive ranges on small guns DONT TELL ANYONE!
knexsniper1
knexsniper1
Answer 11 years ago
yes very clever, tell a secret on an international website on which anyone can see it!
Fred the Penguin
Fred the Penguin
Answer 11 years ago
...........SILENCE I i_am_canadian heavy cannon YOU!!!!!!!
Fred the Penguin
Fred the Penguin
Answer 11 years ago
well now i shoot you with my light cannon
knexsniper1
knexsniper1
Answer 11 years ago
AAAAAAAAAAAAAAAAAAAAA!!!!!!!!!!!!!!!!!!!!!!! it's in my head!!!! the bullet went in and didn't come out!!! x.x
willrandship
willrandship
11 years ago
If you use thin ones, then ur not screwed if one breaks in the middle of combat.
knex obsessed
knex obsessed
Answer 11 years ago
but if 1 breaks that will reduce the range
finfan7
finfan7
Answer 11 years ago
and if you use a thick one and it breaks what happens?
TigerNod
TigerNod
Answer 11 years ago
Be prepared for that and carry extra bands with you.
TigerNod
TigerNod
Answer 11 years ago
True, but only if you want something like a knex gun contest. If you just want to shoot some stuff, use thick.
knexsniper1
knexsniper1
11 years ago
The thicker ones are the best because they are used for force, and when there is more force, then the bullet can travel farther and in turn, increas the accuracy. my sniper uses two #64 rubberbands and it shoots 80+ feet! It is very accurate and can shoot a water bottle from a distance of 50 feet accuratly. i hope that this helps! Good luck!
Killer~SafeCracker
Killer~SafeCracker
11 years ago
Add big ones to increase the strength dramatically and thin to fine tune.
TwistedParadox
TwistedParadox
11 years ago
Use thin ones, thick ones will result in a very hard to pull back firing pin.
Mr. Stealth
Mr. Stealth
11 years ago
From these answers so far, try getting something in the middle, but on the thin side. Try #64 rubber bands or surgical tubing for the best results.
dsman195276
dsman195276
11 years ago
unlike what the others said, i find it like this: fat rubber bands give more power, are harder to pull back, and break less of the time(due to the size of the rubber band) thin rubberbands seem to give more range(not kidding, this is only true if the gun has a big pull back through, because that range is due to the fact that thin rubberbands can stretch more, making the firing pin pick up more speed, which is what give the ammo it's range), are easier to pull back, and break more then the thick ones(because the thin rubberbands have a thinner "body", and are more prone to be rubbed down easier) take your pick.
DJ Radio
DJ Radio
11 years ago
1 thick rb. It gives you more power.
TigerNod
TigerNod
11 years ago
Just use a lot of big ones, and if you are really after some serious power, use everything you have: both big and small!
The Jamalam
The Jamalam
11 years ago
depends. I use lots of very thick ones :D
Miles Tails Prower
Miles Tails Prower
11 years ago
It all depends on how much you use. 1 fat rubberband is about the same as 4-5 regular bands.
dynno97
dynno97
11 years ago
for RBG: thin ones work best, for real knex guns: use thick bands
maid63
maid63
11 years ago
many thin ones take up a lot of space and it wastes a lot, but thick ones take up less space, and they waste very little and also, the small ones break very easily
I_am_Canadian
I_am_Canadian
11 years ago
I like strings of thick ones. They get great power and dont wear out.
ajleece
ajleece
11 years ago
one thick one. if you use thin ones they wear out too soon!
